Greetings,
I have a Wii + Syntax Olevia 537H. Using the component cables, the image from the Wii fails to fill the screen. Instead, it leaves about a 1/2" black border around the image.
I was wondering if converting my component connection to VGA via the X2VGA2 might correct this problem. Has anyone used the X2VGA2 with a Wii?
http://www.x2vga.com/
