AVS › AVS Forum › A/V Control & Automation › Remote Control Area › Polaroid TV Code For Comcast Remote?
post #1 of 12
We recently purchased a Polaroid 24" TV from Circuit City:
http://www.circuitcity.com/ssm/Polar...oductDetail.do
I am having problems programming my Comcast remote to operate the TV.
We have the Comcast OnDemand 3-Device listed here:
http://www.comcast.com/remotes/
They do not list any codes for Polaroid TVs in the manual and I am not having any luck with the search (9-9-1 etc). Does anyone know what codes to try for the Polaroid TVs?
post #2 of 12
Try the mitsubishi tv codes.
post #3 of 12
Keith, did you have any luck with the Mitsubishi codes? Also, what's your opinion of the set so far.....my mother-in-law is thinking of getting the same TV.
Edmund, she has a new standard DirecTV receiver which I believe comes with the RC16 remote....what do you think the chances are of finding a TV code, Mitsubishi or otherwise, that will work with the Polaroid TV?
post #4 of 12
The polaroid owners who had success finding universal remote code to work, it was a mitsubishi tv code. But there are many polaroid owners where the mitsubishi tvcodes have failed to work. The new Directv remotes like the rc32bb and rc32rf now list 11 polaroid tv codes, only the first one is in the rc16, its 10765. give code 10463 a try too.
post #5 of 12
Thanks Edmund.
post #6 of 12
Unfortunately, I've had no lucky finding a working code. The Mitsubishi codes did not work and I even called Comcast and Polaroid and they couldn't help either. We haven't watched the TV much yet (its our 2nd bedroom TV) so I can't comment much on the quality of it.
post #7 of 12
Have you tried codes 0463 and 0156? try all keys when testing the codes.
http://www.remotecentral.com/cgi-bin...read.cgi?10093
post #8 of 12
Nope. Those don't work either.
post #9 of 12
Has anyone found a working code for this yet?
post #10 of 12
You can forget a code for any remote you owned before the purchase of the polaroid. The are now 14 polaroid tv codes in the newest UEI made directv remotes, the rc64 series.
post #11 of 12
Try 11523
post #12 of 12
The code 11523 is a winner for the TLA-01911c polaroid television model. i just tried it with my comcast cable box remote and it works just fine. i have all the basic controls i need for controlling my television's volume, channel, inputs, etc. from my comcast remote now. i hope this information helps someone in the future who has also spent many, many frustrating hours trying to figure out the remote code for the polaroid TLA-01911c model television for the comcast remote. and thank you comcast for your lack of thorough listings of television manufacturers universal remote codes both on your website, and by your phone and field technicians.
  Back to Forum: Remote Control Area
