Originally Posted by
radchad3
Hello everyone! I received so much inspiration on this thread that I thought I would provide some progress pics of my project! My equipment includes:
MA 5-29-26 rack
MA HBL blanks
MA RSH custom shelves
Cisco Explorer cable box
Pioneer BDP-51FD
Sherwood R-972
Crown XLS 402 2 Channel amp
Let me know what you think and thanks!
radchad3, your set up looks really nice.
I am planning a set up that should be very similar.
AV Closet:
We are currently building a HT and I made a dedicated media equipment closet (30"W x 24" D) at the rear.
There is a 2'x4' cut out through the rear wall of the HT into the media closet. The front of the rack and equipment will poke through that front opening into the HT and the rear of the rack will stick out into the closet behind.
There is a door on the other side of the closet so I will have clear rear access to all the equipment. There is a whisper quiet ventilation fan at the top and a air register in the front bottom of the closet that will draw fresh air in from the HT. The air flow will enter from below the rack in the front and exit out the top. The fan is controlled by an in line thermostat.
If I rest the front end of the rack in the cutout so that the rack front is flush with the interior of the HT wall, I think I could squeeze a 26" DEEP rack in the closet, but it would be tight in the back, although with the closet door open it shouldn't really matter. Even so, I just decided to stick with the 20" deep rack. None of my equipment is deeper than that and even if I get something deeper than that I don't mind it sticking past the end of the rack.
AV Rack:
Here's what I'll probably be getting:
Slim 5-29 (20" deep model)
3 x MA Custom plates (for AVR, BDP, and Power conditioner)
1-3 x Emotiva rack ears (for amp(s))
MA Blank plates
Equipment (The stuff I'll put in there):
Onkyo 3009 (MA custom face plate)
Oppo 93 (MA custom face plate)
Belkin PF60 (MA custom face plate)
Emotiva XPA-5 (URE-4 rack ears from Emotiva)
[Possibly 1 or 2 Emotiva UPA-2's. I have 2, but don't know if I will use them in this set up. If I do, they will be mounted with the URL-2 rack ears from Emotiva.]
The 5-29 has a 29U height.
The components above are 15U worth of stuff. Plus another 2 for each UPA-2 that I add. Plus I'll probably have some stuff like a Roku box hidden inside but not showing from the front, so another 1U-2U for hidden stuff.
I was thinking of just getting the 5-21, but felt that it would just be too tight and not really leave any room for expansion.
On the other hand, the height of a 5-29 will not fit in my 2'x4' opening, so I will have to reframe the height of that opening. It's already drywalled and painted, but not trimmed out or carpeted, so a pain, but not horrendous.
But I figure I should just bite the bullet now rather than (probably) continually regret it later, and constrain myself to almost no room for expansion (especially if I end up installing both UPA-2's).
I will pad the width of the opening to more closely fit the 19 1/8" width of the Slim 5 rack before trimming.
