AVS › AVS Forum › Display Devices › CRT Projectors › Resistors on NEC C Drive
post #1 of 9
Do the 3 watt 1.8ohm resistors have to be replaced with exact counterparts?
I can get 5watt 1.5ohm or 5watt 2.2 ohm but can't find 3 Watt 1.8 ohm ones.
post #2 of 9
http://www.mouser.com/search/Product...lkey283-1.8-RC
Mouser part number 283-1.8-RC
No minimum order.
Scott
post #3 of 9
Thanks Scott, Doug
post #4 of 9
Glen, I got some locally from Farnell. Still cost more for the shipping than the part..
post #5 of 9
I have some Glen, how many did you want?
post #6 of 9
If you want a few then you can order them here:
http://au.farnell.com/jsp/endecaSear...lts&sku=343705
post #7 of 9
So they might have the 470 ohm capacitor for the Deflection Board as well?
How do I know which is the low ripple ones in their catalog?
post #8 of 9
They definitely have 330uf, which will do. Panasonic Low ESR/High Ripple.
I have an original Rubycon 470uf kicking around, if you get desperate, but it's old and unused, and would need reconditioning (google).
post #9 of 9
I think I will buy a new one, I was just confused as to the ripple numbers they quote on that site. I am not sure what constitutes high ripple vs low ripple.
  Back to Forum: CRT Projectors
