This is my 1st post. After reading this forum for a bit, I have decided to use Monoprice to purchase an HDMI switch since my TV only has 1 HDMI input and I have 2 sources (Dish vip622 box & upconvert dvd player).
Before I place my order, I need to know whether there is any difference b/t the $98 5x1 enhanced switch and the $28 2x1 manual HDMI switch on monoprice's website? I only need 2 inputs, not 5, but will pay the extra money if there will be a difference in picture quality.
There is also a 3X1 Enhanced HDMI Switch with built-in Equalizer (REV.2.1) for $71 on monoprice. Will either of these present a distinct advantage other than more inputs than the $28 2x1 switch? I will be using the HDMI cables off of their site with this switch if that makes a difference. I also do not mind manually switching it without out a remote so that doesn't really matter to me - only the picture quality.
Thanks so much!
Thanks so much!
I was wanting to place my order in the next day or two but wanted some feedback 1st b/f I do. Thanks...
? Cool! Glad to see you here.
