My Experience so far:
I've had a projector setup for nearly a decade now, I was never really into it I just like the big picture experience it offered. My first projector was an old Barco 500 that I won in a bet (long story).
I moved into a place where I couldn't fit that behemoth so I ended up buying a Boxlight "Raven" shortly after it was released, it seemed comparable to the Infocus X2 and I snagged it for about $200 less then the X2. While the Raven's image is much clearer/sharper I've been disappointed with the contrast and color compared to my old CRT ever since I purchased it (about 2 years ago now).
I'm in a little better financial situation now and I'd really like to get something I'll enjoy beyond just a big picture.
My general usage:
The primary use is for gaming, I have an Xbox 360 and a Wii, and I often play older consoles as well such as PS2, Xbox, Dreamcast, and Saturn (yes, I have a Saturn).
I watch a lot of DVD movies as well, but I have a good upscaling DVD player. I might also consider purchasing an HD-DVD or BluRay player within the next year as well but this is not as important to me as the gaming aspect as the PJ will be used for gaming 4 days out of the week and movies maybe once every other week.
What I'm looking for:
I'm definitely looking for something 720p native or better but obviously good 480i interlacing is very important as well considering many of the older consoles only support that mode. RGB support would be nice too (for things like the Saturn) but it's not vital to the decision.
Ideally I'd like to spend about $2500 but there is some leeway with that.
The thing that bothers me the most about my current projector is it's horrid black levels, worse contrast ratio and overall dim picture. In gaming I often have to crank up the brightness to see what I'm doing in darker games, which often ruins the ambiance. Adjusting for more accurate black and the image is just dim. (right now the screen is about a 96" diagonal in widescreen mode and the projector is ceiling mounted 14' away). even worse is max zoom at that distance the picture doesn't even fill the screen leaving a few inches on either side before the black masking.
Current unit's I'm considering:
I've been keeping my eye on some of the more popular 720p units for a while now such as the HD1000U and the HD72
however after reading though the recent "Highly Rated Home Theater Projectors" rundown on projector central I've changed my focus to some more newly released projectors.
After glancing over the spec sheets and reading a number of reviews I really like the following:
Sanyo PLV-Z5 (LCD)
Sharp XV-Z3000 (DLP)
Mitsubishi HC3000U (DLP)
My lingering questions:
Basically all of the aforementioned projectors look like solid units but I have a few concerns that I haven't been able to find answers to.
I realize that in general DLPs have better black levels and contrast ratios then the LCDs however the PLV-Z5 is rated at nearly double the contrast ratio of the XV-Z3000 and the HC3000U. As for black levels I really couldn't find how how the Sanyo performed, am I to expect it performs worse then the others just because it's an LCD? And if so would better black levels or better overall contrast ratio work better towards the type of generally dark games I like to play?
Most importantly how do these units stack up in terms of latency? particularly when scaling 480i or 480p video (usually over component or VGA)? This is one element that I haven't been able to find any info on.
Another thing that bothered me was that both DLP units require very close mounting positions, I'd need to re-mount and re-wire my current setup to meet their needs (which is doable but not all that appealing) though I'm mostly concerned with the mounting height and keystoning in this regard, my ceilings are fairly low but I fear I'd have to go with a pole setup which I'd really rather not have to do.
Lastly is cost concerns. The PLV-Z5 is quite a bit cheaper then the XV-Z3000 and the HC3000U at about 1600 as opposed to about 3000. However if I put this off for another 2 or 3 months and save another $1000 I could afford one of the new 1080p LCDs like the Mitsubishi HC5000BL or the Panasonic PT-AE1000U. Would it be worth doing that? being LCDs would they still not perform as well in terms of black levels as the DLPS even though they're essentially a class ahead?
I live in the central-northern part of NH so it's difficult for me to find real world demonstrations of projectors to help make my decisions. I rushed into my last projector purchase and regretted it so I'm just trying to make sure I make the right choice this time. and hopefully this next projector will last me at least until 1080p LED DLPs reach <$3K prices
My general usage:
Sanyo PLV-Z5 (LCD)
