AVS › AVS Forum › Blu-ray & HD DVD › Blu-ray Players › Panasonic DMP-BD10 - 1.4 firmware...
Panasonic DMP-BD10 - 1.4 firmware... - Page 3
post #61 of 232
Thanks Much!
Got it!
post #62 of 232
Vista supports formatting the CD in two ways:
1) Live File System (Default)
2) Mastered
Make sure you pick Mastered. I forgot to look at the formatting options and on the first disk I received the unsupport message.
As soon as I prepared a new disk using Mastered, all went fine.
Bryan
post #63 of 232
All is well downunder. I updated to 1.4 without a problem! I just used windows xp drag and drop to copy the file onto the cd writeable drive. Then i right clicked and wrote the file to the CD.
Thats 2 firmware upgrades since i've had the Panny...can't wait for DTS HD and Dolby TrueHD!!!
post #64 of 232
Same here Alex no probs in upgrading.
post #65 of 232
Is picture quality like PIONEER BDP-HD1 after this update ? Or maybe better?
post #66 of 232
Easily as good, if not better...
post #67 of 232
What you've found so better?
Colors?
Noise?
Detail?
What?
post #68 of 232
Have you actually tested both on the same system?
post #69 of 232
Although I do not own the panny is the pq better than the pioneer just at 60hz? I find it hard to believe it is better at 24hz. I know the panny does not do 24 but my display does that is why I am asking.
post #70 of 232
I have and I prefer the picture on the Panny. Not that there is anything wrong with the Elite. It is a fantastic player. The Panny, in my opinion, puts out a slightly sharper image with richer color. It is also superior at upconverting DVDs.
post #71 of 232
Dont forget the audio Ben.....
post #72 of 232
Originally Posted by joshd2012 View Post
The Panasonic uses the same chip as the Sony and Pioneer (though, each is slightly customized, as I understand it). There is no reason - that I know of - why they couldn't do a firmware upgrade to enable 24fps down the road.
Panasonic assigns dedicated video processor chip for upconversion and picture quality control, while Sony and Pioneer are doing that process in the Sigma chip. If that video processor chip is not capable of output 24p, firmware update is nothing to do.
post #73 of 232
The NS chip in the Panny is capable of 24p, so hopefully they will offer this down the road.
post #74 of 232
Thanks Kris,
Do you think Panasonic will be watching this discussion? There is a lot of interest in obtaining 1080p24 around here.
Alternatively, is there a way to communicate this to Panasonic?
post #75 of 232
I just went out and bought a Panny from Tweeters today and I noticed mine has 1.3 version right out of the box------Has anyone else seen a 1.3 version on their player?------I have not heard of 1.3. It seems to play perfect so I'm wondering if I should bother with the 1.4?
post #76 of 232
Originally Posted by CraigN View Post
Thanks Kris,
With the addition of 24P this Panny would definitely have it all, and be King Dog!---Heck, I'm thinking it's the best player right now. I have only had it for one day and I absolutely love this thing!------
post #77 of 232
Originally Posted by John Ballentine View Post
O' yea. Panny was sounding pretty good until you reminded me of this. (Still trying to decide on a BR player.)
Doubtful firmware update can correct this short coming.
Originally Posted by chuckken View Post
Yes, it is a short coming...There are quite a few of us who want 1080/24 for our setups...If the unit lacks something which other players have, it is usually called a "shortcoming"...and that is putting it mildly... Wow!...the next thing you know you'll want us to go back to analog outs!...(how archaic!)...
Want to talk about a player's shortcomings? Try playing a CD on a Pioneer or a Sony!
post #78 of 232
My new Panny should be here next week. Should I do the firmware updates from this thread or do the setup adjustments on the other thread first?
post #79 of 232
Wait till you get the unit and see which version it has. Mine came with 1.3, but most arrive with 1.0 0r 1.2. You might get one with 1.4 already installed----- It doesn't matter when you do the settings, you can do them before or after the updates------if you do it before the update, the unit remembers the settings and adds them to the update.
post #80 of 232
This isn't a Toshiba. Getting the latest firmware only fixes issues, not cause new ones.
I happen to also have a Toshiba HD-DVD player and have updated to 2.0 with no problems so I don't know what you are talking about.
post #81 of 232
Same here... Getting an firmware update that bumped us up to TrueHD was a real bummer.... Hope Panasonic get there soon
post #82 of 232
The 2.0 firmware added Black Crush for DVI playback.
I dont use DVI so theres no problem at all at least for my setup
post #83 of 232
Me either----HDMI all the way!-----
post #84 of 232
I'm confused. Isn't this a thread about the Panasonic? Why so many comments about the Toshiba?
post #85 of 232
joshd2012 was bashing the Tosh firmware upgrades for some reason so TomsHD and I were just letting him know we haven't had any problems with ours----is that ok with you?
post #86 of 232
BTW, I did download and install the 1.4 after all and have no problems whatsoever with my new Panny player----I absolutely love it!------
post #87 of 232
Panasonic knows how to do firmware updates. Maybe they should give Toshiba some lessons.
Sorry, couldn't resist.
ss9001
post #88 of 232
Panasonic isn't without its problems when it comes to firmware. The last one before this gave the player CUE issues that they still haven't resolved. So they actually added a problem rather than getting rid of one. So I wouldn't go pointing fingers too much at Toshiba.
post #89 of 232
I bought my Panny at Tweeter and I noticed it was double clear taped, but it had a factory seal on the box that said, "This package has been inspected in accordance with regulations"---and when I checked to see what firmware was installed, it was 1.3----which I thought was kinda weird. However I updated it to 1.4 and have had a perfect running machine. Maybe this is why I have had no issues?----At any rate, I love my Panny!-----
post #90 of 232
Panasonic UK have sent me a DMP-BD10 for review, which came to me as v1.0. I upgraded it to v1.4 - and now it has CUE when playing BD movies. I'm sure it didn't before - it was instantly noticeable on the red Fox "WARNING" screen at the beginning of the Fantastic 4 disc.
unlike the DVI and stability issues gained by upgrading the Toshibas.
Weird - I never had any stability problems from upgrading my own HD-A1, that's the first I've heard of it...
