AVS › AVS Forum › Audio › Home Theater In A Box › difference between 2 cables...
post #1 of 6
just wondering what the difference was between the 2 followin optical cables from monoprice...
1) PREMIUM 6FT Optical Toslink 5.0mm Cable w/Fancy connector
http://www.monoprice.com/products/pr...ormat=2&style=
2) 6FT Optical Toslink 5.0mm Cable
does the "fancy connector" on the first one serve any real purpose? thx
post #2 of 6
No, the fancy connector does not make a difference. Either of these cable will serve you purpose.
Jon
post #3 of 6
Is it just me, or is the only difference the gold ring? I guess if you want to dress up the mass of cables on the BACK of your component rack...
post #4 of 6
the major diff is that the 1st one is out of stock right now and the 2nd one is still about 1/2 the price or better then what you will buy in a B&M
post #5 of 6
They will both do the job in an identical manner, IMHO.
I switched from coax to Toslink b/c of the possibility of electrolytically induced corrosion with the coax's RCA type plug. So far the sound is just as good and the cable is a bit easier to hide. Not as easy to connect and disconnect, though.
Doug
post #6 of 6
optical cable is just that, light. Any optical cable you buy, be it $1 or $100, will offer the same performance.
  Back to Forum: Home Theater In A Box
