As described in this thread here, I am converting my detached garage into a home theater and media room space.
Right now, as you can see from the photo, the walls are mostly drywalled, and the ceiling is not. I will be pulling off the old drywall, because it is in sad shape and because I want to re-wire the space.... and add an internal false wall.
I'll take this opportunity to insulate well in the walls, and in the ceiling.
But what kind of insulation to use? I live in California, where freezing temperatures are uncommon (usually) and it does get hot in summer, but climate control is probably going to be fine with any insulation I use, I think. So two factors matter:
1. price. I'm already busting my budget, so something on the lower end of the price scale is good.
2. sound. Although I'll have treatments in the room, and I don't care about a little sound spill to the outside, and I will be using Green Glue under the one layer of drywall where it is fastened to the studs, is there some insulation that is better than other insulation, both in terms of the sound in the room, and leakage outside?
(For example, should I be mail ordering OC 703? Is there something I can pick up at Home Depot? etc.)
