A while ago A LG tech was on the BH200 forum saying he was testing A new beta firmware for the BH200, which was released for A short time alowing the new HD codecs to be bitstreamed. He hinted that there were hack's for the BH100 and was supprised no one had found them "yet"....
Good find Camds. How did you come across it? Are you sure it's even an MR table you're looking at? It could be for anything.
He said there was a BH100 SD DVD MR backdoor hack and BH200 SD DVD & BD MR backdoor hacks. I imagine there is a BH100 BD MR hack too but I never asked. That's all I was able to get out of him.
I'm not "that" surprised the BH100 hasn't been found. While I can well believe it's a decent player it was an embarrassment for LG and thus nowhere near as many people bought it as they'd hoped. The more owners the more chance these hacks will be discovered.
I don't know if it's an MR table. The screen shot only says "EEPROM Edit Table" and there isn't any reference to what the values do... I found it going through a list of other LG Player unlock codes.
EDIT Looks like the first 4 sets of numbers will determine the region and possibly
what it should output with regard for NTSC and Pal for the respected SD DVD formats, what do you guys think?
here is the method for checking your firmwear incase some of those numbers also tell the firmware version
Setup>TV Aspect>Select 16:9> then hit 1 3 9 7 1 3 9>Enter
Athanasios
41 55 HEX spells "AU" in ASCII
55 53 HEX spells "US" in ASCII
So if someone has the guts to experiment and change the region code and see if a disc will play we might have something here!! And then they would change back to the original code of their player to see if it reverts back. It should work. We'd know more if some knows what on the player reads that eprom we want to change? If its the "region coding blocker" then we might be on the right track
Athanasios
Where all weighting for you to be the first to experiment with this new fined Athanasios come on be the brave one....
I tried these 3, no luck to get Region 2 coded DVDs to play on my US player. I guess we need a proper Euro snapshot.
When you put back the original numbers did it go back allright?
And did you try your normal DVD region and the Blu ray same region disc to verify if it would change anything.
Also it may need a reboot(restart and the 5 second type) after you change the code, did you try that as well?
Athanasios
Yep, I put it back and all is well. I rebooted after entering each setting. I think it may not be the first two bytes, other LG players seem to control region codes with bytes 4 and 7.
Could be so....the next two bytes are different on Camds( 00 8D) and Mine( 00 00) We definitely need a euro player shot.
When you say Region 2 do you mean Japan or Europe? If it's a European R2 disc it's likely to be PAL too. So sadly won't work.
Same error: "Check disc". I tried a Euro region 2 disc. I suspect the player does support PAL; it would be silly to have two hardware designs. There are posts out there with people changing both byte 4 and 7 on some LG players to make them region free.
If it's an American Player it won't support PAL. There is no reason to give a North/South American Player PAL when no discs are PAL. AFAIK no discs released in North/South America have ever been PAL.
It won't be hardware but some software tweak. The BH200 is the same, no PAL support. There is a BH200 SD DVD MR Hack but on North/South American Player it only works with NTSC DVDs. It's common practise to make North/South American Player only support NTSC by default. Whereas European/Australasian Players support both.
p.s - Have you tried a non-R1 NTSC disc? Maybe from Japan R2, R3 or South American R4. I'd imagine a Region compatibility error would say something like "Wrong Region". That way you'd no for sure it's not a PAL error you're getting.
But id you also try a us version disc after to see if it also plays after the digit change? i was thinking then maybe that what the first two bytes are, to change from a NTSC only player to a NTSC/PAL player and then bytes 4 and/or 7 enable multi region play?
Sorry can't give you a photo of the UK EEPROM settings but they are
44 45 00 82 00 05 00 40
This works! I can now play Region 2 DVDs on my US player. Output can be configured to 576p/50Hz or 1080p/24Hz. In Region 1 mode, it enabled 480p/59.95Hz and 1080/23.98Hz. So the hardware supports both PAL and NTSC + the two HD standards. I suspect the last digit of byte 4 (2 in this case) has something to do with the region. Now, I wonder if there is a "region free" setting...
