Ok now we need to figure out the third byte the mexico one is 01.
hmmmm?
Athanasios
I bought alot more HDDVDs from the USA than UK.
) by setting it to 80. Yep, it did not work quite the way I imagined, but, as you say, it might be a step in the right direction. The player (and myself) are from Poland, the BDs I tried are "No country for old men", "I am legend", "Casino Royale", "Patriot" and "PotC - the curse...", all of them multi region in fact (imported from USA). Now (set to 80) the DVDs region 2 DO NOT WORK (check disc msg). When it's set to 82, PAL DVDs work fine. I do not have anything region 1/A to test yet (NTSC don't know) - that's why I'm not sure it works at all. And one more thing - all the testing wouldn't be possible, if you guys hadn't come up with the EEPROM table. So if it finally works (BD region free or region A) - next time you're in Poland, I owe you one
. Casino Royale is Region A in America but everywhere else it's Region Free.
reverted back to factory settings and just sit and wait to get a region A BD. Hope that someone in the meantime will find it out.
. I just have lots of ideas and some knowledge about region coding.
. I will be able to soon, which is why I am so interested to find out.
