LG Employee: Some people may be able to unlock a lot more since the BH100's made dec06~april06 contain to broadcom IC's. I think it was May07 they took the extra one off the board. Anyway the BH100's that have 2, one of them is disabled. And the one that is disabled what does it do? Maybe a little something to do with HD.
Bradavon: are you abbreviating HD-DVD to HD and mean HDi was included but disabled?
Any idea why kit sold in The Americas has PAL disabled by default? Sure I know nothing in The America is in PAL but it still seems odd when it's so easy to enable/disable it. Why not just leave it enabled?
Lastly, is there any way to do any long term damage by altering any of the values in the EEPROM menu? Presumably you can always put it back to defaults? I just don't want to go bricking a BH200 by tinkering too much.
LG Employee: PAL is just disabled since it is sold in North America. It is easier to just disable it via the menu, remember these are made on an assembly line so when they are making them for a certain region they just change the options in the menu for that run of units.
No long term damage, this is how it is done in the factory.
I guess I should put a word of caution about changing the menu numbers. There is a chance of bricking a unit. I do not have a list of numbers that will do this so just a word of caution for everyone. For people who have the ability to return the unit to a store for exchange, no fears change the menu to whatever you like and see what happens.
For legal reasons the extra IC was disabled. This was the only way the BH100 could be sold. You may thank the battle between bluray and HD for that one. Neither one of them wanted a player that could do both. Of course differences were worked out so to speak and the BH200 was able to do HDi.
The "service port" on the back of the BH100 is not for service. It was just called a service port again for legal reasons. In reality it is an ethernet port. You normally do not see service ports with link lights. A few Dec07 units do say ethernet instead of service, if anyone has one of these, a collectors item
Bradavon: Any idea what Julio Cohen has done here to achieve SD DVD MR? - http://www.avsforum.com/avs-vb/showthread.php?t=1010650
It's been confirmed this hack doesn't alter the values in the EEPROM menu.
LG Employee: Now what Julio did looks like a region code hack program. You can download these just do a google search. I am not sure if he modified an existing hack program so it would work with the BH200 or if he just took an existing program and just used it and it worked. Either way like I was saying before I am quite surprised nobody has done this sooner.
Man if we could find the original programing to enable the second broadcom chip........... I alway wanted to hook up the ethernet port to my router and see if it was visible. But with out the software enabled in the unit it wont help much, maybe we can send emails asking LG to now enable the second chip and the ethernet port for those who have these units. I knbow they most likly wont but its worth a shot.
Athanasios
