AVS › AVS Forum › Video Components › Home Theater Computers › HTPC - Mac Chat › Best LCD TV/Monitor to use with Mac Mini
post #1 of 8
I'm looking for a LCD TV/Monitor (around 20) to use with my Mac Mini (Intel) in regular basis. Therefore it must perform as a good monitor as well.
post #2 of 8
In a different forum discussion, someone said that the Dell lcd monitors are the same identical specs as the APple monitors for much less money; I haven't verified this, but pass it along for your research and consideration...
ken
post #3 of 8
Well they use the same exact screen if im not mistaken, the only difference is the casing.
post #4 of 8
yes, that's what I was told as well...
post #5 of 8
Are you talking about the W2306C or the regular monitors?
I need one that will also work as a TV with at least 1 S-video input. (Preferable if with internal tuner) Then, this is the only in dell's website that fits my needs.
Do you know if the mac mini can work with it in native resolution? And how good is the image when using as a Tv?
post #6 of 8
Originally Posted by Brazilian View Post
I’m looking for a LCD TV/Monitor (around 20”) to use with my Mac Mini (Intel) in regular basis. Therefore it must perform as a good monitor as well.
Did you find one ?
edit:sorry it is 2 years old thread.But still need 19-20 inch lcd.
post #7 of 8
Today, you have many options.
I have a frind with one LG - m228wa and he is quite happy. Its much than the Sony I bought 2 years ago!
post #8 of 8
I think that the best is actually Apple. I have a place you can check out that will help you pick the best monitor and helps your see what one you need.
  Back to Forum: HTPC - Mac Chat
