Originally Posted by
urbansouljah
My Sony tv (kp-51ws500) looks extremely dark when I use my Sound & Vision (Best Buy version) disc to set black level. The colors are also way too oversaturated when I set color using the blue strip. I'm not sure what I am doing wrong. Also has anyone ever seen contrast set correctly on any HDTV at around 60%?
in addition, out of the box, this sony doesnt have a correct color decoder. You need to go into the service menu and change AXIS to 1 from a default of zero.
Make sure you select Warm as the temperature.
Black level on the 500 is probably one of the best, this series just needs a little tweaking out of the box compared to alot of other CRT in the past. Please be aware that many people always find the set dark when you calibrate it, its not the HIGH CONTRASTY look anymore.
You should probably used a disk such as AVIA, DVE to set your levels, but neverthelees, I find Pixar movies THXOptimer decent enough..try that..
