Hello guys,
I have a NHT speaker set ( ST-4s, SC2, HDP-2s) I'm going to bi-wire my fronts and Im wondering what brand spade concectors I should get. Are the Monster solderless ones any good? I can do my own soldering if needed. I noticed with the crimp or solder ones only contact is from the outside of the wire, with the monster ones I looked at it would be the center of the wire making contact? I will be using Monster Cable M series 1.4s wire ( I got a 250ft spool for $300). I will be using a NAD T785 reciver. And the cables have to be about 30ft long. Any help would be great.
