AVS › AVS Forum › Audio › Home Theater In A Box › How long are the speaker wires on the Onkyo S590s?
post #1 of 3
Could find any information anywhere about it. Just curious if I'm going to need to buy longer wires. I would probably need at least 30 feet at the longest.
post #2 of 3
I would replace them with 16ga regardless. A roll of 100' of 16ga will run around $20 at a home supply place.
post #3 of 3
I think they're just short of 30 feet, like 25 or so. Can't remember. But yeah, if you're not sure, just buy some Home Depot wire which will be an upgrade and the exact length you need.
  Back to Forum: Home Theater In A Box
