OK, got my LG BH100 today to review, and there are some pro's and con's, and some of the con's are pretty damn big, and not the one thing everyone has complained about: iHD or HDi.
Pro's:
1) EXTREMELY fast. The power-on time destroys the Samsung, Panny, Pioneer and Sony, and definitely the HD-A2 as well. The load times are on par if not faster than all as well for both HD-DVD and BD.
2) Ease of use. Very easy to setup and use. Picture quality is outstanding at 1080i and 1080p.
Con's:
1) Cheap build quality like the HD-A2
2) No ethernet for direct networking or updating. The RJ-45 is a service port only.
3) No 24P (at least for now)
4) Even though this is the first player with DTS-HD MA decoding internally, LG screwed the pooch as the HD decoding only decodes 2-channel over HDMI. Only the 5 analog outs decode 5.1 for HD. This should be an easy fix via firmware, but again, this is the biggest mistake I have seen on any of the players, as this was a bigger plus to me even than HD-DVD playback so I could enjoy Fox and MGM BDs with lossless compression over LPCM 5.1, but nope. I won't go back to analog out's when I have a preamp that can decode LPCM 5.1 over HDMI.
5) DD+ again is only 2-channel PCM over HDMI when set to PCM. It is decoded as DD legacy when set to bitstream. Plus must also be decode and sent to the analog outs to get 5.1.
6) DD True HD is also 2 channel PCM, and that does NOT change even on the analog outs. Again, as with plus and DTS-HD, this should be able to fixed just the A1 series was upgraded with a firmware upgrade.
7) No HD-DVD interactive support. This is really not a big deal for at least me, as I RARELY watch supplemental features, even though the Warner and Universal interactivity is pretty cool. The LG pre-renders an overlay menu on titles with the HDi layer, and it still does allow for scene selection, audio, play and the norms.
This player could be great if it got a quick firmware update, but for now, I wouldn't buy it unless you have no use for advance audio codecs via HDMI LPCM. This lack of support is a generation back at least, and something I am personally extremely disappointed in.
This mini-review is also posted in the BD forum.
Pro's:
Con's:
