AVS › AVS Forum › HDTV › HDTV Recorders › TV ATSC Tuners more sensitive than USB tuners?
post #1 of 7
I've noticed that both my EyeTV 500 and the new Hybrid ATSC tuners don't get nearly as many channels as the ATSC tuner on my TV (A vizio 47" LCD), using the same antenna connection (split between the three). The TV tunes far more channels and has very little difficulty locking on to signals that the two EyeTV tuners can't find. I'm wondering if this is normal, or bad usb tuners in general, or the vizio just has an excellent tuner. It makes recording difficult when the recorders don't see the channel I'm watching!
Chuck
post #2 of 7
Not all tuners are created equal.
post #3 of 7
The term "Hybrid ATSC tuners", exactly what is considered a "Hybrid" tuner? Any analog & digital tuner?
The six digital tuners I had or have ( one STB,5 TVs'), sensitivity of all of them was fairly equal. The exception was a older HD tuner card for the PC. Sensitivity was terrible compared with these internal tuners.
The big difference is how thery handle ID'ing the channels, especially on cable.
post #4 of 7
In general the newer the tuner chip the better the performance.
post #5 of 7
USB is a connection, not a tuner. If the stations in question are digital, all the tuners are ATSC tuners. It depends on which generation tuner is in the device.
post #6 of 7
ATSC tuners are being sold as a USB stick that plugs into the USB port of a computer and puts the video signal on the computer monitors. Thes devices are very small and typically are less sensitive than other types of ATSC tuners. They are often called "USB Tuners"
post #7 of 7
My AutumnWave OnAir GT USB tuner has the 5th generation LG tuner. It works as well or better than any OTA standalone tuner I've owned.
  Back to Forum: HDTV Recorders
