HDMI repair
post #1 of 9
I bought a rather expensive 50ft. HDMI cable from BetterCables for use with my projector about 2 years ago. It has worked fine until recently. Recently I notice it seems to have some kind of short in it. I have it connected to an HDMI 5 port switch and I occassionally lose the signal. If I mess with the cable, I get the signal back. I tried direct connecting the cable to my DVD player to be sure it was the cable going to the projector and it is. Direct connected I lose the signal and then if I bend the cable around a little I get the signal back. Any way to put a new connector on an HDMI cable to save buying another $300+ cable and have to tear up my ceiling to re-run it?
thanks,
post #2 of 9
I can't help you with cable repair or with fishing new cable through a ceiling, but maybe I can help you with spending $300+ for another cable. Have you tired monoprice.com for cables? They get good reviews from users on this site.
post #3 of 9
i have seen connectors on line but they seem impossible to solder for the average hacker. why dont you srr if your cable manufacturer will replace i know the problem is in wall next time conduit
post #4 of 9
Yes, monoprice is great. I buy a lot of stuff from them. A cable from them is about $100 instead of $300, but in cables of this length (50ft), I am not sure I want to go with a less expensive cheaper made cable.
Just as an FYI, another place to get good inexpensive cables is www.firefold.com
post #5 of 9
post #6 of 9
Originally Posted by ericsilv View Post
http://www.pacificcable.com/Picture_...me=HDI-19P-KIT i found one you can solder
Hey, that's great! Thanks! I will get this and take it to Radio Shack or something to see if they will solder. I am not too good with the solder iron.
Thanks again,
post #7 of 9
I would try somewhere other than a Radio Shack (unless yours are different than ours) as they seem to have gone from experienced technical personnel to the warm body theory. I would try an electronics/tv repair shop.
post #8 of 9
I decided to contact BetterCables where I had purchased the cable from to ask them if there is a way to repair the cable. I quickly received an email stating a new cable was on the way to my house with a pre-paid return postage for the old cable. I didn't expect that at all. I am very pleased with BetterCables and the customer service is fantastic.
post #9 of 9
Hmmm, just had exactly the same experience.
I Bought the cable in October 2005, and in the last 6 months or so I've started losing the connection. I assumed it was a dodgy connection in the DVD player, but connecting it to my Onkyo resulted in the same problem.
As you were, I was seriously annoyed having spent a large amount of money on a duff cable. But in fairness to my local distributor, they are replacing at no cost to me.
It sounds like a design fault they are aware of - but if they treat customers this well, it'll do them no harm, and probably a lot of good.
