ok...i've tried an experiment (i'm new at this). i've set up my spl meter at listening position, on a tripod, pointing at the ceiling. i've entered the distances from the speakers (7.1) to that sweat spot into my denon 3805 receiver. the main volume on the denon at 0.0. then i set the meter at 70. using the internal receiver tones, i adjusted the individual speaker db's, so that i got 75db readings on the meter(70 plus 5). the fronts are set to small (though they are large floor standing). the sub was 'off' when calculating all speakers. i then turned on the sub lastly and kept that spl reading at 70db. (isn't the sub supposed to read approx. +5 more than the others?).
here's what i got:
LF: +2.5
C: +2.0
RF: +2.5
RS: +6.5
RSB: +1.0
LSB: +1.5
LS:: +2.5
SW: +6.0
then....i tried the meter at 80. to get 75db's i would then simply subtract 5db's.
i fiqured that the outcome would be the same.
here's what i got:
LF: -1.0
C: -0.5
RF: -0.5
RS: +3.0
RSB: -2.5
LSB: -1.5
LS: 1.0
SW: +5.0
why so different? my room is set up for a projection theater, but because of a support pole, the seating area is off center. any advice is appreciated. i have ordered a reference mic and also an avia disc....but wanted to try this first. thanks.
here's what i got:
LF: +2.5
C: +2.0
RF: +2.5
RS: +6.5
RSB: +1.0
LSB: +1.5
LS:: +2.5
SW: +6.0
here's what i got:
LF: -1.0
C: -0.5
RF: -0.5
RS: +3.0
RSB: -2.5
LSB: -1.5
LS: 1.0
SW: +5.0
