Hey X people. Its been some time since I last checked in. Not sure how many X users are still out there. I still am happy with my card. No problems at all. But just maybe on the horizon..........................................
There are a couple of sound cards that come to mind for those that would like to take that plunge. Asus Xonar ST and RME Hammerfall 9632.
My world is strictly audio. I'm not a PC gamer or movie buff, on the PC that is. My card is plugged directly into my sound system.
The other preferred option for that upgrade is an USB external DAC. Now we have an abundance of choices and price ranges these days. It has been all the rage for the last year or so in the the audio world. Personally my budget would include The new Musical Fidelity M1 upsampler dac ( £399 No US price yet ) or the upcoming Wadia Digital 121 upsampling Dac/pre will be available in two versions, $999 for base unit and $1499 with a built-in headphone amplifier.
http://www.musicalfidelity.com/produ...1DAC/M1DAC.asp
and the up and coming...
The 121 will have 5 digital inputs. (2 S/PDIF, 1 TOSLINK, 1 USB, AES/EBU) The 121 will feature a Digimaster Filter, along with a Swift Current analog section. The new DAC will also have the direct connect output with volume control and multiple voltage outputs. The 121 will also have a headphone jack with discrete output. With the 121, Wadia expects to set a new standard in affordable digital to analog converters. And as well cover all sampling rates from 44,48,88, 96, 176 and 192 khz. All inputs, excluding the USB (24-bit/96kHz), input can accept up to a 24-bit/192kHz input data rate. Once the data enters the system, our data sampling technology uses a spline interpolation algorithm to up-sample all incoming data to 24 bit/ 384kHz for high performance conversion. The algorithm reduces interpolation error and creates highly accurate representations of the original performance. The 121 will hopefully be ready by the end of the year.
