Originally Posted by taranu
I've been lurking here for a long time and I've been following the X-Meridian threads for a while. I've been using the Echo Gina 3G for a while and I thought I'd try the XM since it is praised by a lot of people. Well, I finally got it this weekend and I had the chance to listen to a lot of music since then as well as a few movies. I also upgraded the opamps to the LM4562 discussed in the other thread (X-Fi vs X-M).
I used the analog outputs to connect to a Rega Mira intergrated-amp and a pair of PMC FB speakers. For software I used MCE2005 and for movies TheaterTek. To make the story short, the X-Meridian was not even close to the Gina 3G, especially in the low frequencies. The sound was always thin compared to the Gina 3G. I went back and forth between the cards and the difference was very obvious, especially with music. With movies the difference wasn't very big and the XM had an interesting sound, not necessarily worse.
Now I wouldn't say that the XM sounded bad because I did manage to get used to it fairly quickly and it was so much better than the integrated sound card. It also projected a pretty wide sound stage, very similar to the Gina 3G and the midrange was decent. The Dolby Digital Virtual speakers feature was pretty interesting with movies and I thought it sounded better with it on (on 2 speakers). For movies, the difference between XM and Gina 3G was not very obvious but still the Gina3G's sound was more solid.
I'll probably keep the XM in my HTPC for a few more days and after that I'll move it to my other computer (gaming and work) where I'm sure I'll get a lot of benefits over the integrated one. It's a good enough card that I'll keep it. I'm also going to replace Gina's opamps with the LM4562s this weekend (they're not the DIP type so I have a friend doing it for me) and see if its sounds any better.
For those wondering how the XM will stack up to the Lynx2b I think the answer is pretty clear since the Lynx is supposed to be much better than the Gina 3G.
Interesting comparison. Just curious, what settings were you using on the XM?
It would be an easy problem to correct if I had the schematic of the sound card or wanted to take the time to reverse-engineer it (I don't) -- just a matter of changing some resistor values, probably. (While I was at it I'd try to reduce the large quantity of electrolytic caps that seem to be present in the signal paths.) As it is, it's clear to me that the designers of this card are pretty clueless.
