Im not sure if this is the correct place but here we go.
Ok I have a Sony E2000 RPTV and the native resolution is 720p. I also have a Panasonic Progressive Scan DVD player (not sure which model as I am at work) and an Xbox 360 that I am currently using to play my DVD's.
Im just wondering what I should use to get better PQ. I thought that the 360 was upconverting but apparently that is only trough VGA and my TV does not have a VGA port. So do you guys think that the DVD player or the 360 would be better?
