I am trying to tweak the reception from my basement office for a particular channel (FOX). I have an ATI HDTV Wonder and am using the antenna that came with it. I stretch the coax cable across my basement over to a window on the other side of the house (in the direction of the station I'm trying to get) and can get it intermittently. I think the signal strength is 30-40%.
Am I better off:
1) Running the cable outside to get it higher, or
2) Buying a better indoor antenna?
I currently only get 3 networks (Fox, ABC, PBS) and would really like to get the other major networks, too.
Am willing to spend $50-$100 if it will do that.
Your help is appreciated.
Am I better off:
