* There are two ways to receive local digital/HD broadcasts in the St. Louis area. The first, and by far simplest, is to subscribe to Charter Cable. Unfortunately, Charter doesn't currently provide all of the available St. Louis digital stations. To date, Charter is offering KTVI-DT (FOX), KMOV-DT (CBS), KSDK-DT (NBC), KETC-DT (PBS) and KPLR-DT (WB).
WRBU-DT (UPN) is not offered by Charter, but this isn't a major issue, since WRBU's digital station isn't capable of passing the UPN network's HD programs. And with the pending merger of UPN and the WB, this is even less a pressing issue.
* On the other hand, if you're a satellite customer, or you're only interested in receiving the free OTA digital chanels, you'll need some sort of antenna -- either indoor, attic or roof mount.
* Forget most of what you know about receiving traditional analog television via an antenna, as digital broadcasting is for the most part a different animal.
The first and most important thing to know is that digital signals, once received, tend to be highly stable. The sort of artifacts that you may recall about pre-cable antenna reception of local stations isn't all that relevant to digital reception. For example, in the digital realm there's no visual equivalent to the analog artifacts known as "snow," or "ghosting."
And in most cases, a digital signal won't slowly fade in and out as was sometimes the case in fringe analog reception areas. For the most part, with digital broadcasts you either receive the signal and have a near-perfect picture and sound, or you won't get anything at all.
In addition, barring significant topographical or architectural obstacles between your location and the transmission towers, digital signals appear to be more robust in terms of distance they can travel without degradation. While it's the exception rather than the rule, there are instances where digital OTA signals have been received as far as 120 miles from the tower.
So, just because you may have had difficulty with OTA analog signals in the past at your location, that doesn't necessarily mean you won't be able to receive digital OTA signals.
* All of the current St. Louis digital/HD stations are currently broadcasting in the UHF spectrum. The UHF channel assignments for local stations appears below:
26 - KPLR (WB)
31 - KDNL (ABC)
35 - KSDK (NBC)
39 - KETC (PBS)
43 - KTVI (FOX)
47 - WRBU (UPN)
56 - KMOV (CBS)
Today, all St. Louis stations are "simulcasting," with the traditional analog broadcasts via one frequency and the digital/HD broadcasts through another. For example, KMOV sends its analog broadcasts out as VHF channel 4 and then simulataneously sends its digital broadcasts as UHF channel 56.
As the transition to digital broadcasting progresses, there will come a time when the analog broadcasts will be discontinued and stations will only be transmitting digitally. While this switch from analog to digital was originally scheduled to take place in 2006, it's almost certain that the analog shutdown will be deferred for at least a few years.
Note: The analog shutdown has now been set by Congress for February 17, 2009. This seems a FIRM date, but there are some observers/commentators who believe that not enough has been done to date to inform viewers of the impending change and they suggest that this shortcoming could lead to further delay of the analog shutdown.
* While the signals for digital/HD broadcasts are made up of binary data (zeros and ones), from a viewer perspective, there's nothing special about the antenna required to receive those broadcasts. As noted above, the actual transmission takes place over the UHF spectrum. That means that if you already have an old UHF-capable antenna on your rooftop or in your attic, there's a good chance that it will receive some, and possibly all, of the available local digital broadcasts. The only way to conclusively determine if that older antenna will carry you into the digital age is to test it.
However, it is possible that in order to maximize signal integrity you might need to upgrade the cable run from an existing antenna to your distribution point(s), especially if the antenna uses the flimsy ribbon-type cable connection. If you need to replace the cable for an existing antenna, RG-6 quad-shield coax is recommended. A 1,000-foot roll of RG-6 quad coax can be purchased for around $75, though it is possible to buy smaller quantities at a higher per-foot cost.
* If you're starting from scratch and need to purchase an antenna, there is some merit in selecting a UHF-only antenna. While a combo VHF-UHF antenna would likely work in many situations, a UHF-only antenna will normally give better, more reliable results. If you do have an existing antenna and it isn't capable of pulling in all of the stations in the area, there's a good chance that swapping out for a UHF-only antenna would result in better reception.
* Without officially endorsing one antenna over another, here are some suggestions that should work for most viewers within a 45-mile radius of the St. Louis transmission towers.
But first, bear in mind that antenna reception is one part art and one part science. What works in one location might not work across the street due to topographical or physical obstacles in the signal path at that second location. But that sort of anomaly is rare, and antenna reception is normally achievable with some reasonable effort and determination. But it is important to understand that there are no certainties and the only way to find out what can be received with an antenna in a given location is to test one yourself or arrange for one to be installed by a proven installer.
For outdoor or attic antennae, ChannelMaster sells at least two UHF-only models that you should consider -- the CM4221 (retail approximately $30 -- tax not included), which is a 4-bay rated for 45 miles, and the CM4228 (retail $50), which is an 8-bay rated for 60 miles. Winegard has the Prostar 1000 model PR-4400 rated for 45 miles, and the PR-8800 rated for 60 miles. Radio Shack also sells a UHF-only antenna (catalog # 15-2160, $30 retail) that is worth considering.
As a general suggestion, avoid antennas that appear to be working overtime to not look like an antenna. While it's true that traditional antennae are unattractive and a lot of people consider them to be eyesores to be avoided at all cost, the newer streamlined, aerodynamic antennae seem to compromise reception capability in exchange for a more friendly appearance.
For indoor antennas, there are many options here as well, but the current performance leader is the Zenith Silver Sensor (ZHDTV1). The Silver Sensor used to be available at several stores here locally, but recently distribution has dried up and the only sure way of finding the SS is going to be online. Figure on a cost of around $40.
The excellent performance of the Silver Sensor is probably in part due to the fact that Zenith actually designed the technology responsible for the transmission of OTA digital/HD signals, known as 8VSB.
Again, there's no reliable way to predict if an indoor antenna will work in your location, short of buying one and testing it. The good news here is that most of the major retailers have reasonable return policies, so it's unlikely that you'll be out major bucks if it turns out that an indoor antenna isn't up to the job in your home.
26 - KPLR (WB)
31 - KDNL (ABC)
35 - KSDK (NBC)
39 - KETC (PBS)
43 - KTVI (FOX)
47 - WRBU (UPN)
56 - KMOV (CBS)
![Star Trek: The Original Series - Season 1 [Blu-ray]](http://cdn.avsforum.com/9/99/50x50px-ZC-999c9e6a_B001TH16DS-51Lx0QeVATL.jpeg)
