AVS › AVS Forum › HDTV › Local HDTV Info and Reception › St. Louis, MO - HDTV
St. Louis, MO - HDTV - Page 427
post #12781 of 12787
Does anyone have a recommendation for an outdoor antenna installer?
My wife and I decided to cut the cord. We were cable free from 2007-2010, so this isn't uncharted territory for us. But we moved at the end of 2010. Our old house came with a "vintage" antenna in the attic that work pretty dang good.
Right now I'm using a small indoor RCA antenna from Walmart that is pulling in all the channels except 46 and while I do get PBS, it can be very spotty and PBS is important for me.
So I'm in no big hurry, but I do want to get real reliable setup soon.
post #12782 of 12787
Jeff,
Generally, a 4-bay antenna or a medium-range UHF Yagi should work in the Edwardsville area. A lot depends on your particulars (terrain, trees, obstacles) as to what might work well. You could also try something along the line of a ClearStream 2, suggested because it can usually be found in most Best Buy stores.
post #12783 of 12787
Thanks, but I am also looking for someone who does the installation.
Does anyone do that around here.
post #12784 of 12787
I don't know if they go to Edwardsville but these guys did one for me-Very satisfied: A-1 Satellite and Antenna, 7570 Watson Road
Saint Louis MO 63119, 314-961-9333
post #12785 of 12787
post #12786 of 12787
YES!!!!!
Touch was a rather uneven show that worked best when his "Jack Bauer" personality came out. I hated it when he got beat up by the bad guys. It just didn't seem right. At times, he fought like a girl.
post #12787 of 12787
Originally Posted by moman19 View Post
YES!!!!!
LOL!
