See update at bottom.........
Originally Posted by
Thrummer
Just finished intalling and running eq.
Haven't even listened to it yet... taking a little break.
Instructions were good, but I wanted to check on a couple of things.
I did the level matching procedure on the center channel, but it came in less than a half db different, so I didn't bother to make any corrections to it, or the other levels. I expected the levels to be more different, so I hope I did this correctly.
AND, the distance and trim that the SVS Eq gave were 24'1" and - 2.7 db, so I entered those into MCACC manually. The MCACC values were 6'10" and -8.0 db, so that seems weird too.
Each MCACC memory position has it's own levels, so do I have to adjust them in all of the memory positions? I usually only use 2 or 3 of them at most.
But the proof is in the listening. Will fire it up shortly and give it a go.
Wife is out of town so will have to restrain myself.
Picked up the new TRON on BD for viewing later.
Looks like I'm getting down to around 28Hz in my room. (Aperion rates it: -3dB, 20Hz - 200Hz -- -6dB, 16Hz - 200Hz)
[/IMG]
http://imageshack.us/photo/my-images/7/svseqafter.jpg/
Hey all, just wanted to update. I relocated my sub away from the corner and re-ran Audyssey.
It seemed more complicated this time. Hope it went ok.
Moved it forward about 3 feet, still along the wall, but out in front of the tv now. The before and afters are both better. Especially the after.
Much flatter, and with more extension. 24 Hz vs 30 Hz (or so). Woohoo!
Uploaded with
ImageShack.us
