Sorry, I rather have them drop another Analog channel instead of them going the 3-1 route. If Quality means anything, which I'm sure it does to most people here, then that is the best option. If you noticed FIOS has already picked up on this and is claiming in their commercials they have the best HD quality because they pass thru the full bitrate on their HD channels, something they couldn't do before until Comcast started this multiplexing thing so I hope they are only doing this temporarily or Subs will be changing over to the competition and that affects their bottom line, something you like to point out around here often.
Can someone give some detail on switched video, how tv's support it, when Comcast will switch, how are cable cards affected, required hardware etc.
