UPDATE:
Just put on the new 2 GHz splitter, and there is a noticeable difference. The average droppage is about 10 (so a channel in the 90s range of signal now down to the 80s). Several of the channels in the high 70s are now in the 60s, however, and the signal on the digital box is odd. There are several channels not coming in at all (BBCA, for one), and that one is in the low 80s on the TiVO. I'll wait to try the amp when it comes in to see if that helps. But this should work for now, as even the lowest channel signal is the upper 60s-low 70s.
Question: Should I connect the amp where the cable comes in, and THEN to the splitter and then TiVO and the digital box, or connect the splitter first and then to the amp?
