Originally Posted by
walk
After all, Comcast might be forced go about making sure Cablecards work better and are more well supported
in their OWN STBs but that doesn't guarantee the same level of service with 3rd party STBs.
What are the chances Motorola/Comcast come up with a workaround for SDV using CableCARD 1.0 if they are forced to use CableCARD STBs starting July 07?
Now ask yourself what are the chances if there are zero Comcast STBs using CableCARD?
The mandate for Comcast/MSOs using CableCARD at least assures that whatever infrastructure decisions Comcast makes need to take into account making sure their own CableCARDs deployments are not left in the dust. As long as a feature can be done using CableCARD 1.0, TiVo et al can at least piggyback or reverse engineer that solution.
If you don't feel SDV is a big issue for TiVo S3 read these posts:
http://www.tivocommunity.com/tivo-vb...&&#post4848958http://www.lightreading.com/document.asp?doc_id=113263
"According to the report, Comcast execs plan to have a quarter of their footprint enabled for SDV by the end of 2007, and launch "the next 50 channels of HD" as switched channels."
I don't think they will adding VOOM channels anytime soon. So, there are bound to be many popular HD channels that will be added. Popular in the sense of HD, not to the general subscriber base of SD channels, at least not yet. They probably think this is the only way to get a lot of HD channels on the air. Whatever the case, future Comcast HD is going SDV, and don't be surprised if the current HD channels go SDV, as well.
http://www.tivocommunity.com/tivo-vb...&&#post4846037
TWC Austin
I have a tivo s3 installed with Austin TWC and a whole bunch of channels are now on SDV, not just unpopular ones. I've had to install a Time Warner HD DVR in parallel just to get the channels I'm missing.
BTW I don't see why it is a foregone conclusion prices will increase. If people start buying their own PVRs and Comcast only has to carry inventory for $30 CableCARDs vs $500 Motorola 6412s why does that necessarily result in price increases. If CableCARD viability speeds up the transition to digital from analog, doesn't that tend to help them in the long run?
The STBs that Comcast uses may cost a little more in the short-term but that will go down as volume goes up.
Personally I'm not willing to accept at face value statements from the MSOs that the pricing will go up and they will pass it on to us. There is only so much room the pricing can go up before it starts driving customers to Dish/DirecTV, that's why it is nice to have competition.
