I was watching FOX 21 tonight on Verizon FiOS and was wondering what was up with the anamorphic look. I thought, since we get FOX-21 HD they were taking that feed for the SD channel (5) and doing something wierd with it.
Then I tuned OTA (Zenith DTT901) and found 21.2 was indeed 16x9 ratio. I checked again with my Sylvania STB and it showed it to be SD 16x9.
This seems like a good compromise as I couldn't believe you could get anywhere near an acceptable picture with both 1080i and 720p on one channel. I'm not sure if 21.2 is 480i or 480p as there's nothing on the net about this. I'm sure it just happened as I usually tune in FOX 21.
I just hope they don't flop back to 4x3 and make me look stupid.
So check it out!
Believe me, it was 16x9 as I typed this.
So check it out!
