Thanks, Joblo! That was *quite* a thorough reply, and I appreciate your taking the time to do so. (Not news I wanted to hear, but as good an explanation as I'm likely to ever get!)
I finally 'solved' the problem by dedicating a second recorder to only capture the 9:00 pm programming rather than wait for the 12am reruns when the main recorder wasn't busy.
Haven't tried recording two shows at the same time on the two different recorders using the passthrough and internal tuners on both the recorders, but I think this will be okay as I can always use an aux input from the cable box instead to grab the second program and leave the internal tuner set to MhZ. For some reason my comcast feed (to the tuner) has both Mhz and MPT at the same location (22.1, 22.2, 22.3 ) so I had been running into problems setting timer recordings... It seems to be working this way. I will touch nothing!
