Well, I've lurked around for a couple of weeks, so I figure it's time to introduce myself, and I may as well accompany the intro with a few questions.
I'm in the process of buying a home that has about a 31' x 12' semi-finished basement that I'm intending to convert into a home theater. By "semi-finished", it has paneling on the walls, a hideous foam-tile ceiling, and 9" (yep, almost certainly asbestos) vinyl tile on the floor. It also has a dry bar in one corner, with a corner post that happens to be the main waste stack (friends are already plotting how to install a sink over there :-) ).
My intentions (besides a sink and small fridge in the bar area) are to take down the ceiling tile as part of a housewide electrical upgrade, take up the floor tile and lay down carpet or other resilient floor material, and possibly do a raised seating level for the second row. One of my big problems is that my ceiling height (floor to joist bottoms) is only about 6' 7". Initially, I'll probably put my 32" Sony CRT and A/V stack down there (routes to a 5.1 speaker system), but ultimately, I'd like to acquire either a Mitsubishi HD1000U or a Hitachi PJ-TX100 for video (and keep the A/V stack, which includes a receiver and 300-disc CD changer, as well as a home-hacked, 10Base-T equipped TiVo with a 250GB HD).
I'll try to include some photos and/or sketchups over the next couple of weeks, but would wlecome any inital thoughts on:
tile/adhesive removal: I know it's probably asbestos, and I'm ready to take the necessary precautions in removing it -- any suggestions on a solvent that will allow for non-abrasive adhesive removal (and not be more dangerous to inhale than the asbestos fibers)? Once it's removed, any thoughts on leveling what is sure to be a rough-surface floor?
electrical upgrade: Since I've got (and would like to keep) the paneling on the walls, would it make sense to go surface-mount for wiring and outlets? Naturally, since I'm taking down the ceiling, I'll be doing recessed lighting and wiring in a box for a future projector up there.
ceiling height: Can I even reasonably DO a projector in a room with this height? I'm only a beginning videophile, so needing to tilt the screen and/or projector and do some digital keystoning is completely acceptable. Also, thoughts on building a raised platform for second-row seating? 2x4's on edge plus 1/2" plywood decking, then carpet on that?
flooring: What is recommended? Would low-pile indoor/outdoor carpet be best? I've not done an official moisture test on the basement, but by all appearances, it is dry.
ceiling: Again, what is recommended?
As I said, I'll post more information as it becomes available. I'm really just looking for guidance.
