AVS › AVS Forum › A/V Control & Automation › Home A/V Distribution › Speakercraft MZC66 installation tutorial?
post #1 of 5
I just started a job today in which I have to install a MZC-66 among other things. I have not installed any Speakercraft multi zone systems before, and was wondering if there are any tutorials online that I could go through for the software side of the installation. I checked on Speakercrafts site, but did not find any tutorials, even under the dealer section. Actually there was no mention or help at all there, other then a download of the software. I would appreciate any help I can get.
post #2 of 5
I read through that manual a few days ago. I've never installed one before, but it seemed very straightforward. Have you read the installation manual?
post #3 of 5
I did. I thought that there were several areas that it was very vague. Other areas went more in depth. Either way, I finished up today, and was able to figure out a lot of the programming on my own without the manual anyway. I have to say, I am very impressed with the sound quality. I have not installed or heard a Speakercraft system before. I have dealt more with Elan on a small scale and Nuvo on a larger scale. What were your thoughts on the system?
post #4 of 5
I haven't installed it yet. I am actually still comparing it to a CAM6.6 system. I can't decide which way to go. Which speakers did you pair the MZC up with?
post #5 of 5
The speakers were already excisting. The builder installed them. I am not sure what kind they are, I never popped off any of the grills. That is part of the reason I was hoping for your thoughts on the system. It sounded great, and have to assume it is because of the decent quality amp speakercraft uses.
  Back to Forum: Home A/V Distribution
