AVS › AVS Forum › HDTV › HDTV Recorders › Where can i find 5c flag info for 8300hd
post #1 of 3
I have searched but could not find.
Where in the diagnostics for a 8300hd does it show the broadcast flag level?
and what are the copy freely/copy once/etc codes
post #2 of 3
post #3 of 3
Note that with the firewire ports rendered impotent by the last software upgrade, it really doesn't matter what state the 5C flags are in. And TWC (my provider) likely knows this, as my diagnostic page shows that they don't even have the flags turned on anymore. The same is true of the SA3250HD, which was the STB they gave you if you wanted active firewire (per FCC mandate, which they no longer concern themselves with). If you're going to prevent any HD dumping to tape by neutering the firewire ports, why bother with 5C?
  Back to Forum: HDTV Recorders
