Originally Posted by Health Nut
It is true that DTS HD Master Audio uses the core + lossless extensions. Also true that DD True HD uses two tracks simultaneously in parallel: a 640K legacy DD and a MLP coded track.
As far as time delay, there should be a way to incremently delay the video until it matches the audio.
As far as outputting DD True HD and DTS Master HD Audio, They are all output via HDMI... but apparently a couple Blu ray players are capable of outputing the audio simultaneously from the HDMI output and the optical coax. So if you select the DD True HD track from the movie, I guess with those players it is sending the lossless audio thru the HDMI output and the 640K thru the optical output. In any case, there are only 2 players I am aware of that have this capability, and I'm not quite sure how it is being done. I don't want to have to buy one of those players. Currently, I'm waiting on info from Meridian and a few other surround processors at CES... I've been holding out for a solid high end solution for DD True HD and DTS HD Master Audio... Certainly, with HDMI being the standard, I would like to think that D-Box has an HDMI input solution being worked on....
Hi Health Nut,
just see my post above... http://www.avsforum.com/avs-vb/showt...5#post15217865
This could be a solution... it passes the original and unchanged HDMI 1.3 signal including the HD audio and 'strips' the audio off...
What remains to be tested is whether it can handle all HD codecs and whether the legacy codec signal is working with the D-Box controller.
Cheers!
Markus
![Spartacus: Blood and Sand - The Complete First Season [Blu-ray]](http://cdn.avsforum.com/7/78/50x50px-ZC-7898cfb3_B003PIUC02-61cn9w2BeOKL.jpeg)
![Predators (+ Digital Copy) [Blu-ray]](http://cdn.avsforum.com/6/6b/50x50px-ZC-6b2329af_B0040YFR1Y-312ApL7yoXL.jpeg)
Just a fyi.
