AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › For all D-Box enthusiasts !
For all D-Box enthusiasts ! - Page 173
post #5161 of 5810
Any of you D-Box users out there in NEW YORK?
post #5162 of 5810
Originally Posted by xhonzi View Post
The retail version of How to Train Your Dragon 3D does not synch.
This is the silver covered BD DVD version.
Originally Posted by sanderdvd View Post
Update on the 3D support by D-Box:
D-Box will look into the following titles soon to make them 3D compatible because there already is a 2D or 3D anaglyph codec available for these titles:
Captain America : The First Avenger
Harry Potter and the Deathly Hallows : Part1
Journey to the Center of the Earth
I can now confirm as well (sadly) that you are correct about [Journey to the Center of the Earth]. The non-anaglyph one does not synch.
They originally snuck under my radar, but JttCotE and HtTYD are both synching in 3D as of the 15th of May.
post #5163 of 5810
Originally Posted by drvais View Post
I think your best bet is to dl Scuba Steve's home theatre demo disc.
I have these, but they don't have what I am looking for. I am looking for the scenes that D-Box created. They are on youtube but there is a version of these that sync MFX. I can tell because I see I have the codes for them.
post #5164 of 5810
Originally Posted by Russ Rubman View Post
Could you provide a link to the dl please?
I got them off of bit-torrent. I think that is the only way. The download was many GBs.
post #5165 of 5810
Me, and I bought one of your loveseats.
post #5166 of 5810
Saw The Avengers with D-Box on opening day.
I have never been to a D-Box theatre before that but man, that was awesome. Of course I had to keep it turned all the way up.
I would love to incorporate D-Box into my home theatre but they make it so dang hard to order. Would be nice to just get it locally or even a good online source.
BTW, do the home versions move/tilt the same as the cinema ones or do they get special versions to keep the market at bay?
post #5167 of 5810
Hi Pete!
How have you been? Where are you located? We should check each others systems out some time. PM me when you have a chance
post #5168 of 5810
Did you check their site to find a dealer near you? I am in the Dallas area and I was able to demo locally even though I ordered online. It should not be that hard to order.
The motion they use in the theater is the same movements and vibrations they use for the home systems. This is only limited by what you order. For example, there are 2 axis system and the 3 axis systems which are also used in the movie theaters. Furthermore, having D-Box installed in individual seats allows for more motion from side to side, whereas there are options to add D-Box to couches and love seats. I personally enjoy D-Box more at home as I don't care much for the theater seats and having my feet not move distracts from the enjoyment for me. If I do go to the movies, then I still prefer the D-Box seats to the regular ones in most theaters.
post #5169 of 5810
I have a new challenge for my D-Box system: noise reduction
My HT room where my D-Box is installed is on the third floor. My kids on the second floor are scared of the rumbling sound, my wife on the first floor is aggitated a lot too and both my neighbours at both sides also complain from time to time. So I have to do something about this before my wife finds out that there is a master volume that can be decreased!
Serious, isn t there something like a platform I could build to reduce the rumbling of my house and that from my neighbours?
post #5170 of 5810
Is the rumbling noise coming from your platform or the sub?
If the platform is doing it and you can elevate it, perhaps you isolate it from the floor below. This might entail a double layer of 3/4" plywood sitting on top of some rubber feet. Then your DBox sits on that.
post #5171 of 5810
I'm looking for some input. I have an older D-Box Odyssee XL system I bought back in 2007 and has been sitting on a shelf. I'm nearing completion of my theater and went to set it up and one of the actuators failed due to leaking fluid.
D-Box will repair the unit for a fee. But I'm curious to know if anyone else is still using this system and has their system failed or have they had good success. If you've had yours repaired...how long has it lasted since?
I'm concerned that the other three actuators may start to fail as well and may just cut my loses now.
Carpeting is getting installed in a couple weeks and I'd rather not have a seam in the middle of the room for the originally planned D-Box platform.
post #5172 of 5810
I recently made coding requests for:
Puss in Boots
IMAX: Under the Sea
IMAX: Grand Canyon Adventure
Firefly
post #5173 of 5810
D-Box hasn't released the versions you've seen in theatres on Blu-ray. There are some obscure D-Box demo DVDs out there, but they're from several years ago.
post #5174 of 5810
An alternative to Scuba Steve's disc is to just make your own using TSMuxer and multiAVCHD.
post #5175 of 5810
I forgot to report back last week that Battleship's coding is a serious competitor to the work done on The Avengers. It may actually be better! The scenes with the spinning machines were absolutely brilliant. I can't believe they just released two full-length demo worthy movies consecutively. We're going to have a lot to look forward to when these street.
post #5176 of 5810
Can anyone confirm that any EU version of Tintin works with D-Box, I have tried two different with no luck
post #5177 of 5810
Is Red Tails on anyone's short list? I haven't heard much good about it, but I figured I would only watch it in D-Box.
post #5178 of 5810
I have no interest in seeing that movie.
post #5179 of 5810
Not even the train-wreck-can't-look-away kind of interest? I have a friend who was a Tuskegee and he and his friends (so he told me) thought it was pretty favourable. That's the only positive review I've heard and I swore on my mother's grave never to give another red cent to George Lucas... but... you know...
post #5180 of 5810
I don't understand how the motion codes connections/interface work....
post #5181 of 5810
What don't you understand? I'm sure none of us know all of the intimate details, but someone can probably answer your question.
post #5182 of 5810
The DVD or Blu-ray player connects to the D-Box "Controller" via a digital optical or digital coaxial cable. The DVD or Blu-Ray player will send the Dolby Digital or DTS lossy tracks to the D-Box controller in order for the controller to detect and sync with the movie.
The D-Box controller sends the motion information to the seating via a shielded network cable.
If you go with a laptop solution, the D-Box controller hooks up to the laptop via USB and the laptop stores all of the motion codes.
post #5183 of 5810
What about hotels in Edinburgh?
post #5184 of 5810
Does anybody have any new information on Popcorn Hour compatiblity with D-Box (simultaneous unadulterated output to both HDMI and legacy audio)? There is a thread here on the C4 forums that I've been trying to get an answer from a C4 dealer that is pushing them. Doesn't sound to me like the company will commit to compatibility:
http://www.c4forums.com/viewtopic.php?id=11986
post #5185 of 5810
2 D-Box thoughts-
1. How long until they post those John Carter and Journey 2 codes?
2. Does anyone have a used KAI controller they'd like to sell me?
post #5186 of 5810
2 D-Box thoughts-
So much for "available day and date of release".
Now that I posted something snarky, I'm sure they will be up shortly. I'm more interested in Chronicle myself. The availability delay Redbox and Netflix are forced into actually helps us D-Box owners sometimes, at least that is one way to look at it.
post #5187 of 5810
Journey 2 is up (and a few others I personally don't have an interest in) but where are those John Carter codes?!?
post #5188 of 5810
John Carter (3-D) is up. I didn't even see them working on this one. Wow.
post #5189 of 5810
John Carter was D-Box theatrcally. It's been on the "New Releases" part of the coming soon list for months. Same as Journey 2.
Good news that it's up, though.
post #5190 of 5810
Whoops, I forgot it was a theatrical coding. Where is my head tonight? smile.gif
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
