AVS › AVS Forum › Display Devices › Ultra Hi-End HT Gear ($20,000+) › For all D-Box enthusiasts !
For all D-Box enthusiasts ! - Page 199
post #5941 of 6359
Staff from Dbox responded today and also informed me that the new code for Olympus Has Fallen has been released. For the record, it is almost three weeks since I first contacted them. Three weeks to simply resync a movie is not acceptable -- and as I note below, they acknowledged and agreed that it is not acceptable.
I forwarded to Dbox my suggestion that they start their coding efforts with whatever they have on hand -- be it a studio or Canadian source. None of us want that process to take any longer than necessary. But at the same time, I suggested that they order a US retail copy of every movie they code, and confirm that the codes work with US retail copies just as soon as they receive those US retail discs. My specific point is that this situation, that occurs periodically, should NEVER occur again. Never again should Dbox have to be informed by any of us that a code does not work. Based upon receiving a US retail copy, Dbox should already know that a code that they either are about to release, or have already released, has failed. So Dbox already knows this -- and we do not need to inform them, at least not for their largest market in the United States.
The response from Dbox to any emails reporting a failed code should then be "we are aware that the code has failed and will release an update within three business days."
Stress the words WITHIN THREE BUSINESS DAYS. There is no reason that resyncing a code should ever take longer than that. This case -- Olympus Has Fallen -- took almost three weeks from when I first reported it on this site and to Dbox, and that is flatly absurd FOR A SERVICE THAT WE PAY FOR.
Now, to provide some balance, and report on positive developments at Dbox:
I received a very positive response from two staff members at Dbox. The response was "bottom line is you are right that it is unacceptable and it shouldn’t happen. Rest assure that we take this seriously and we are putting efforts to overcome it." (To be clear, Dbox staff did not say that their solution is necessarily what I recommended, only that they are addressing the issue to insure it doesn't happen again.)
I consider that to be a timely and positive step, and am pleased to report that Dbox is addressing the concern. In their defense, it seems to me that movie codes are being released in a more timely fashion, and the web site clearly states when codes are to be released. For example, the new Star Trek code is due to be released on September 13. I also know that they modified their shipping policies within the last year related to repairs from the United States, which is another positive development.
Finally, I have generally found that Dbox responds to emails in a timely fashion, and did modify their shipping policies in direct response to a problem that I had, and suggestions that I then provided. (This case, where they didn't get back to me on a coding problem for two weeks, is the clear exception to what has otherwise been timely responses and corrections to problems that are reported.)
I am very pleased to report on these positive actions by Dbox, and improvements to the service. The Dbox motion chairs are a real hit in my home theater, and people from all over my area visit my home theater to experience it. I love Dbox, and am grateful that Dbox is taking steps to address our concerns and make their product and service even better.
If they can release all movies codes even more promptly -- well, we would all be thrilled and delighted. smile.gif
These are all positive developments, and I wish to thank Dbox for addressing these concerns and for their continuing efforts to improve the service.
Edited by Marty M - 9/5/13 at 10:03pm
post #5942 of 6359
Originally Posted by thxman View Post
What do you want me to test 1st?
Also, new codes for Olympus Has Fallen are out for those who care.
You remember our topic from last year? In this topic you wrote a (very good) detailed step-by-step instruction how to config the virtual serial app. Since I m on W7 X64 I found a free version of a serial app you can find here http://www.hhdsoftware.com/doc/free-virtual-serial-ports/configuration-utility-overview.html. Was hoping you could write a step-by-step guide for this program like you did then.
post #5943 of 6359
Thank you for the update, maybe they can fix Zero Dark Thirty now too smile.gif
post #5944 of 6359
Ok, I'll see what I can do then. Keep in mind that I will need to test this via my laptop (not connected to my Controller). I don't want to mess with my current setup since it is working very well. I'll write up the steps and have you test them. Looking at that app, it should not be too hard.
I assume your iRule setup is working, but you want to maintain some degree of control with your Harmony remote.
post #5945 of 6359
Thanks. Looking forward to it.
I m skipping irule completely. It does not add anything special compared to using a logitech hr.
post #5946 of 6359
i think so,Let's hope we see wider Studio support and also HD DVD-supported formats soon also.thanks P5zQBq
post #5947 of 6359
HD DVD??? I thought that was a dead format. Am I missing something? Why support a dead format?
post #5948 of 6359
I am currently trying to remote control my D-Box Series 4 via RS232 and it just won't work.
I'm not sure what to send to the controller. I'm using this document: http://www.d-box.com/media/docs/Downloads/Production/Files_914-0042-C_EN.pdf
The controller won't reply on any message I send. Parity, Stopbit etc. is correctly set. (19200-N-8-1)
I'm sending something like this:
this.comPort.NewLine = "\r";
char c = Convert.ToChar(20);
this.comPort.WriteLine("*0" + c + "RINPUT");
That should match the description in the document.. First char "*", second numeric id of controller (I already left that out as it is optional), then the separator char (ASCII number 20), R/W, command, carraige return.
But the controller does not respond :-(
Can anybody help?
post #5949 of 6359
Solved the issue... I just used the wrong document :-( Needed to use this one: http://www.d-box.com/media/docs/Downloads/Production/Files_914-0049-C_EN.pdf
Now everything is working fine. I disassembled my Series IV now and now are using the motion controller part together with my HTPC. This is just about 100 times faster now... it was annoying for me to wait about 5 minutes for the Series IV to start up and be ready for operation.. with my HTPC now everything is ready in 1 minute. Updates are much faster, too.
I am using the virtual com ports too, but not the one you linked to. They always gave me timeouts. I am using "com0com"
Edit: One problem remains: The control of the MCI control software via RS232 virtual ports doesn't work if you use the automatic startup mode :-(
Edited by Passi - 9/7/13 at 2:37pm
post #5950 of 6359
Oblivion codes rocked . The movie not so much .
post #5951 of 6359
I have the same issues with these virtual ports so far. Still testing.
post #5952 of 6359
Originally Posted by turls View Post
No, I am really slacking on this. Now that my vacation is over, not sure when it will happen.
Can you test yours again? New codes for Zero Dark Thirty are out. Thanks.
post #5953 of 6359
I will let you know if it makes any difference, should be able to try tonight.
post #5954 of 6359
What's the over/under on Star Trek ID codes being out in the next 48 hours?
post #5955 of 6359
I think we will see them at least by the 13th as advertised
post #5956 of 6359
Double-checked I am up-to-date on codes. No change, there is no sync. This is on the retail Zero Dark Thirty.
post #5957 of 6359
Thanks for the heads up. Keep me updated
post #5958 of 6359
Thanks for checking, my RedBox copy did not work either.
post #5959 of 6359
They are out now.
post #5960 of 6359
They are out now.
Star Trek Into Darkness codes? I want to believe you, but I don't see any mention of them on the site.
post #5961 of 6359
http://www.d-box.com/en/consumer/home_movies
Check upcoming movies. Been there a while.
If I knew they were going to hit that quick on the codes (that must almost be a record), I wouldn't have watched it last night.
post #5962 of 6359
So... we're in agreement that the codes are NOT out yet, right?
post #5963 of 6359
They are out. Confirmed!
Edited by thxman - 9/11/13 at 6:56pm
post #5964 of 6359
Originally Posted by drvais View Post
Apologies. Obvious brain fart led to post in the wrong forum
post #5965 of 6359
Okay! I believe you!
(Shake, Shake, Shake Senora!)
post #5966 of 6359
3rd time is a charm? Maybe, new codes are out.
Update: My Redbox copy is working now. Thanks D-Box smile.gif
Edited by thxman - 9/13/13 at 3:34pm
post #5967 of 6359
nothing yet? Anything I can do to help?
post #5968 of 6359
double post, sorry
post #5969 of 6359
I'll try my retail copy shortly, but how do you know when they update codes? I can't tell when they update previous releases.
Into Darkness was great with codes BTW.
post #5970 of 6359
The guy is a troll who keeps getting us riled up every few months with posts like this.
  Back to Forum: Ultra Hi-End HT Gear ($20,000+)
