I have been having troubles ever since I switched to using an HDMI cable!
I just bought a Panasonic TC-P54S1, I initially hooked it up with component cables because I didn't have an HDMI cable yet. All was fine till I got the HDMI cable.
I had comcast come out, they did all sorts of things to the wiring in the house, and they assured me that it was because I had an old box, so I upgraded from my 120GB box to the new Black 320GB box!
Everything was fine for a few days, then the problem started with the new box. After SEVERAL experiments, this is what I have discovered.
For me, it only happens on Standard Definition channels. It doesn't matter if it's live TV or a DVR recording. All HD programming works fine. If I have the sound going through the Optical output, then the sound is fine, if I have the sound through the 2 component cables, then the sound is fine, but the sound going from the HDMI to the TV gives me the 2 second audio skip.
I have unplugged the cable box from the cable input and it STILL does it!!
I decided to plug in all the 5 component cables and watch TV that way, but when I'm watching a standard def. program, then the DVR suddenly flashes "DU1" and the picture cuts out for about 2 seconds and the DVR switches resolutions! VERY STRANGE!
I have decided to simply watch TV with the stereo on so that the sound doesn't cut out!
Comcast has NO CLUE about any problems, and I wonder if it's a MOTOROLA problem!!!
Anyone with anything helpful to share, please email me at: jpv072900@comcast.net
Jeff
Jeff
