Below are two quick sketches of my room. The risers and the Stage (not shown) have not yet been constructed. Note the Grey areas indicate reduced headroom due to HVAC plenum. I was originally planning on placing my SVS (cylinder) sub at the front on the stage, however even right against the side wall it would still block the edge of my planned screen. It would also be in the path of my right main speaker.
My new planned location is at the back corner of the room on a 5 riser (essentially the same height as the main riser step) adjacent to the 10.5 main riser platform at. I was planning of filling this 5 sub riser with Sand, and fill the main riser with pink insulation. The plenum directly above is partly insulated and constructed with 5/8 drywall. There will be an in wall equipment rack just in front of the sub, but it will be enclosed at the wall as much as possible.
I would really appreciate any comments or concerns about this design.
Room layout - plan view- not to scale:
looking towards the back- not to scale:
Edit: I forgot to add. The floor is concrete but I have a "DriCore" subfloor installed and secured with tapcon screws.
