AVS › AVS Forum › Display Devices › Plasma Flat Panel Displays › Panasonic 50PX60U -- Buttons Don't Work
post #1 of 2
I have a 50PX60U that I bought last spring. This morning when I tried to use the tv only the power button works and none of the other buttons on the front of the tv or on the remote (such as TV/Video, aspect, etc.) work. Has anyone else had this problem? I'm not sure what to do. Thanks.
post #2 of 2
Well, you can try the old unplug from wall and reset it trick. Might work, if not, not sure what to tell ya.... you could try calling Panasonic.
