Originally Posted by
stanger89
No, "done correctly" or "taken to the extreme", you use a lens, and a high-quality scaler and you configure the scaler to slightly pillarbox content between 1.78 and 2.35:1.
Let's get the definition of correctly out of the way:
- In a correct manner; exactly; accurately; without fault or error.
Done correctly and taken to the extreme are not the same thing. SLIGHTLY PILLARBOX! OMG You won't be using the full resolution of the panels.
stanger89
So I guess we shouldn't scale DVDs to the resolution of our panels? Scaling DVDs to 1080p doesn't create a better image than using a 480p display of the same size?
No, you should. The output depends on the quality of the scalar. With DVDs you're upscaling the resolution six times. This massive jump in resolution allows a good scalar to interpolate information for these extra pixels.
Upscaling scope films to fill your panel only upscales the resolution 1.33 times and only in the vertical direction. So now each pixel of source information has to stretch vertically to fill 1.33 pixels. Have you ever seen an LCD that isn't displaying its native resolution? Looks fuzzy to me (because it is) but I constantly find people doing it.
Upscaling works to improve an image somewhat when you have a much larger number of pixels to work with. At what point does it stop hurting the image quality and start helping? I don't know but I'm very doubtful that a 1.33 verticle upscaling is beneficial in terms of image quality. It may be brighter but that doesn't mean it is a better image.
I would love to see some test patterns like I said before. Maybe your scalars are working better than I think. I can test out the scalar on my AE2000U when I get home in a week.
I'll do another post with images to show what happens to pixels stretched 1.33 times vertically.
stanger89
FWIW, most displays have between 5 and 10% overscan.
In that case you're losing between 13 and 18% of the vertical information and 5 to 10% of the horizontal. Fortunately most projectors don't overscan much or will pixel map 1:1. Mine doesn't overscan.
stanger89
Just because something isn't "done correctly" doesn't mean it doesn't work, doesn't even mean it doesn't work well. Lots of people just zoom for scope content, are happy with it, and good for them, that's what matters.
But if you really want to do CIH right, you need a lens, a sled, and a good scaler. Most people choose some tradeoff due to cost/complexity. I don't have a sled or a scaler.
Correctly. Without fault or error. That is how my CIH setup performs up to the screen's AR.
stanger89
That's a perfectly valid tradeoff, as is going without a lens. No reason to get so bent out of shape about some verbage.
Now, you may think there are image quailty benefits to using a lens over not using a lens but both setups can perform correctly with regards to CIH.
The only annoying thing here to me is CAVX stating the following:
CAVX
CIH
done correctly uses an anamorphic lens...
Mark
When the fact of the matter is that
his lens setup doesn't due CIH correctly up to the screen's AR. His 'lens only' attitude coupled with his ignorance is what is annoying.
stanger89
According to IMDB, 2.76:1 is the widest AR used.
According to IMDB
Napolean has a 4.00:1 aspect ratio.
http://imdb.com/title/tt0018192/Quote:
stanger89
Vern's got a 2.76:1 screen with a 1.5x cinema anamorphic lens I believe.
He's close but not quite. His website lists his screen ratio as 2.6:1.
stanger89
What does "directors vision" have to do with using a lens or not. As noted above, most every scope movie shown in a theater is shown with a lens. Films are often filmed through a lens.
All it has to do with is projecting the film properly.
Theaters use a lens because they have an anamorphic source.
Films are always filmed though a lens as far as I know.
stanger89
I don't read it that way, if anything he's saying that most people don't do CIH completely correctly (ie use a finely adjustable scaler to make every AR just right).
A lens doesn't prevent that.
I don't understand that at all.
The only real compromise with a lens is cost.
CAVX
Most of hoever will probably limit ourselves to about 4 ARs
What he says is that most people with lens, himself include, limit themselves to about 4 ARs. This results in an
incorrect CIH setup. This gives you an image that is altered from the director's vision. This is the compromise of some / most lens setups.
Some / most lens CIH setups in fact display certain aspect ratios between scope and academy
incorrectly.
It makes sense. To step up in to a variable scalar is an extra expense.
stanger89
I'm with CAVX, to be completely correct, you need a lens, a sled, and a good scaler really do CIH right. How far down that path to completely correct you go, is up to you. Me, I'll probably work my way down the path until I get there.
Actually inorder to be correct (this is the same thing as completely correct) with your CIH setup you either zoom or if you go the lens route you need the lens, sled (or pass through, or a scaling), and a variable scaler.
You can certainly do it correctly with a lens it just take
a lot of money. I decided to go with the cheaper, less complex, CIH method that allows me to perform CIH correctly for any aspect ratio up to my screen's AR.
