I just bought an Elite 84" dropdown (m84uwh) screen and need to mount it to the wall.
The instructions are a joke, it literally tells me nothing.
Here are the entire contents of the instructions for wall mounting:
Mark the area from the screen mount end cap hole to the wall. Then mount the screen onto the wall (Fig 1).
The only other instructions are for ceiling mounting. When I read this, I almost laughed.
Anyhow, it has some bigger bolt like screws which I obviously cannot use, but it also has 2 smaller screws with sheetrock anchors.
The screen weighs about 30 pounds. Do you think it is safe to use the sheetrock anchors without drilling into a stud? My only other option I can think of is to get a 2x4 and drill that in the studs and mount it to that. I live in an apartment, so I don't want to overdo it. I am not sure how much weight those sheetrock anchors can take, but 30 pounds sounds borderline. 10-15 pounds no problem.
Any advice?
Any advice?
