AVS › AVS Forum › Gaming & Content Streaming › Home Theater Gaming › PlayStation Area › PS3 and it's hardware scaler
PS3 and it's hardware scaler - Page 10
post #271 of 280
Originally Posted by Cucuy View Post
Which Motorola HDTV box do you have? Is it the 6400 series? If so those support both 720p and 1080i.
Personally, I am just disappointed that my 2003 HDTV and my 2006 PS3 don't talk to each other in 1080i. I don't blame either.
Not sure Cucuy, but I've searched around for the options on the menu and have never been able to find anything that scales the SD channels to HD. If there is a way to scale to 1080p for everything that I don't know of I'd be happy to try it out.
post #272 of 280
I ended up buying a receiver that scales up to 1080i for my gaming needs.
post #273 of 280
Does it look like this?
http://broadband.motorola.com/dvr/dct6412.asp
http://broadband.motorola.com/noflas...2659-001-a.pdf
You have to have the Motoroal HDDVR off to go into the HD output menu. Then you can force the output to go to 1080i. But the scaling of SD prgramming and final IQ I guess would depend on the quality of the scaling from SD to HD and the quality of the SD programming. I guess the saying garbage in garbage out would apply here (in addition to the quality of the scaling)
When I said all my HD devices upscaled I was thinking about HD scaling like going from 720p to 1080i and viceversa not going from SD to HD.
post #274 of 280
post #275 of 280
That is the box I used to have at my old place (1st link, 2nd froze my PC). Thanks for the info on the HDDVR needing to be off, maybe it is the same on my model.
Ok, we were talking about different things then I was curious about SD to HD myself. I don't really care if it is 720p or 1080i being scaled personally for my displays.
post #276 of 280
FYI,
2nd link was the manual in PDF format which you can get to (bottom right)from the first link if the direct link does not work.
post #277 of 280
Figured as much. Thanks
post #278 of 280
Originally Posted by HeadRusch View Post
Sony didn't care, they were assuming the PS3 would be a runaway hit the way the PS2 was......and that it would spark people to dump their 1080i sets and move to some 720p or 1080p flatpanel, and then upgrade their receivers too for models with HDMI that could decode 7.1 TrueHD sounds.
So much for that idea
You honestly believe they were fully aware of it, and just didn't care? I can't imagine that being the case. I think the real reason is that Sony Computer Entertainment is an isolated part of the company, and they don't really talk with the other divisions. The engineers simply goofed on this one, and they weren't collaborating with any of the other divisions, so nobody was there to tell them they messed up. They didn't find out about it, until we found out about it.
Very few HDTV devices will scale to 1080p. That is a more recent development. But virtually 99.9 percent will scale 720p to 1080i and vice versa. That is what we are talking about in this thread.
post #279 of 280
Yuck, I just fell into this tar pit. I'm new to the PS3 and discovered that I was playing GRID at 480.
So I guess I have to look at the game more carefully to see what rez it supports before buying.
post #280 of 280
Yes, it continues to disapoint looking at how many big-name games do not upscale to 1080i/p. LBP and Far Cry 2 being the latest games that I have not purchased due to this problem. Check here for a comprehensive list so you can avoid this problem in the future: http://boardsus.playstation.com/play...43717#M1543717
  Back to Forum: PlayStation Area
