I've been thinking for a while now of building two "budget" line array speakers. By budget, it will probably end up being the most expensive pair of speakers I've owned; however, by audiophile standards will be very cheap and most likely distasteful. I myself am not an audiophile, though my expectations for sound quality are far above most of my peers.
I am, however, a big fan of rock and metal. High SPL, with sound quality equal to or preferably greater than my current system, are the goals for my next project. Honestly another thing I love about line arrays is the intimidation factor when someone walks into a room and stares between me and the 6.5' tall speakers
Currently, my stereo setup is a pair of Cerwin Vega E-712s receiving about 250w each. Their sound quality is definitely acceptable to me. Of course I wish for better quality, but I could live on this level for the next few years
If you believe CV, then the E-712s are 98db at 2.83v/1m, giving them significant output for the power they receive.
The line arrays I'm thinking of building will consist of:
DAYTON PT2B-8 PLANAR TWEETER (partsexpress 275-085)- 4 or 6 in each array
DAYTON PA130-8 5" FULL RANGE P.A. DRIVER (PE 295-010)- 9 or 12 in each array
The low end will be filled by two Elemental Designs 13kv2s that I have laying around, probably 300w Bash for each.
The crossover will be a basic active crossover at 12bd/oct slope and limited adjustability, though I really want to upgrade this in the future. I'm having a hard time finding active crossovers that DO NOT use balanced XLR connectors (under $600 that is), as my amps use RCA. The woofer lines will probably cut off at 50hz, around where the powered subs pick up.
I think the sensitivity of such an array would far surpass the Vegas I currently own. First, because it is a line array. Second, because it is bi-amped and actively crossed, there is no passive crossover to waste energy as heat. The greater sensitivity goes along with the goal of greater SPL. I won't always have a kilowatt of power on hand like some here may
The parts I've listed here will pretty much max my budget (I would have enough for the basics- wire, solder, wood, glue, screws, stuffing, etc). Does anyone have suggestions? Are the PT2 planars total junk? (I've read mixed reviews--from an audiophile standpoint, I'm sure they are poor compared to what one would expect from a planar/ribbon tweeter... or a silk dome for that matter. Others seemed to love them.)
If you believe CV, then the E-712s are 98db at 2.83v/1m, giving them significant output for the power they receive.The line arrays I'm thinking of building will consist of:
