AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 409
post #12241 of 62195
Originally Posted by LarryChanin View Post
Hi Andrew,
If I'm not mistaken you actually posted three sets of graphs.
Yes, your first set of curves had no subwoofers.
Your second set of curves only had an Audyssey LinearX + sub included. There wasn't a similar Audyssey Denon + sub.
Your third posting of graphs included a LinearX and a Denon curve, but their was no mention of any subwoofers or crossover values.
Are you referring to graphs you may have posted in another thread?
If I missed the Denon +sub graph can you please provide a link?
Larry
I posted only one graph using LinX + sub and the file name is audysseylinx+sub.jpg
The audyssey+subXX.jpg were graphs measured using the Denon mic with crossover at XX freq.
post #12242 of 62195
Originally Posted by Jim Cate View Post
OTE=audyssey;15947047]So far, I prefer the "Audyssey-flat" curve, which seems the most realistic.
Hi Jim,
I echo your observations. I have been using Audyssey Flat for all of last year because I feel that the default Audyssey setting is a little lacking in air and transparency.
Now I use a LinearX mic for measurement and I don't feel that I need to use Audyssey Flat anymore. It has tighten up my mid range response and hence mid region is more flat/less boosted and the perceived effect is better HF extension.
Albert
post #12243 of 62195
Originally Posted by Mike25690 View Post
. . . That's why I visit the Audyssey thread often, and it's been even more interesting than usual lately.
That's because of all of the "feeling the love" that was going on a few pages ago . . .
post #12244 of 62195
I thought I felt something funny!
post #12245 of 62195
It's a geometry issue. -
So what to do? Well, after mulling it over, my solution was to go through the Audyssey setup procedure once more, this morning, but to manually adjust the orientation of the mike for each test such that the plane perpendicular to the mike was approximately congruent with the top of the respective speaker being "chirped." In other words, the mike was oriented for each speaker individually such that it wasn't pointed toward the respective speaker, but instead was perpendicular to it's upper end. Remembering not to disturb the mike during the actual tests, of course.
Perhaps some would consider this a lot of trouble and hassle and not worth the effort. But all in all I am pleased with the results, and I'm getting some pretty good sound, better than anything achieved previously with Audyssey. (Probably not as good as the analog bypass setup, but balanced and very sweet.)
Jim Cate
Originally Posted by kjgarrison View Post
Way back in this thread someplace I posted just this idea; of moving the mic to perpendicular for specific speakers. In my case it was in-ceiling surrounds, which the mic "points at" at about a 30 degree angle when it is pointing at the ceiling. The response was that it would require an improbable amount of agility to quickly make the mic changes between chirps.
So.
I'm very interested to hear more about where you hid between adjustments and how you were able to get in, make the tilt, and get out in the short time available.
Jim, can you elaborate on your method please?
post #12246 of 62195
Lively debate is a good thing, no?
The 3.6 Maggies I know well. As suggested, great top end, all the "air" is there.
If one's taste is inclined to large orchestral performance they are among the best in the proper room.
On the other hand if one requires imaging to put you there at, well for an example that some might understand, the Blue Note, the 3.6 Maggies might be found somewhat lacking.
Point is that separate from what Audyssey does , and in my experience amazingly well, there are many other factors.
And when will we all get away from the idea that response above 20kHz means anything?
Yes, I know respected reviewers in the past ........
Joe
post #12247 of 62195
Now you've done it Joe...Prepare for 10 pages of "192 kHz is so amazing I can hear the air and presence in sub-atomic particle vibrations"
post #12248 of 62195
It is the greatest! My speakers can reproduce waves into the GHz range...I use my speakers to microwave my coffee!
post #12249 of 62195
No just more hot "air and transparency".
post #12250 of 62195
How much attention does Audyssey MultEQ XT give to the subwoofer channel?
Also how well would it timbre match a front stage with the Main and Center channel speaker being from a different manufacture? I am running Klipsch RF-83 mains and a RC-64 for my center.
I am using a pair of Cerwin-Vega CLS-215's in a shelf system in another room. What would happen if these speakers were used as L/R mains in the HT room?
John
post #12251 of 62195
8 times more attention than the other channels.
post #12252 of 62195
Chris,
My front left and right speakers are 6'+ tall. My ears fall in the middle of the bottom of 3 15" high ribbon tweeters. My center is normal height (4') for a standing speaker, though, with the top 30" being ribbon tweeters. So thee's still about 36" of ribbon tweeter above my seated ears (which is great for listening while walking around.)
Because of the height of my left and right speakers, should I be placing the mic vertically at the top horizontal plane or just at my ear level?
The Maggie discussion has me a bit confused about this.
Shelly
post #12253 of 62195
Hi Andrew,
I can't find that graph in any of your three postings.
How about posting a link to it?
Larry
post #12254 of 62195
Originally Posted by shelly View Post
Chris,
Shelly
Hi Shelly,
For speakers with a standard tweeter we recommend placing the tweeters at ear height and the mic at ear height. In your case (and Jim's) the tweeter is much larger and operates on a different principle. Ribbon tweeters are much more sensitive to vertical placement of the mic (and the ears for that matter).
My suggestion would be to start with the mic on the center line of the tweeter even though that would put it above your head. What Jim tried was tilting the mic, but still keeping it at ear height so that if you draw an imaginary line from the center of the ribbon it grazes over the top surfaces of the mic. I can't predict which one will give better results, so it may be worth trying both.
post #12255 of 62195
Hi Shelly,
Thanks for the prompt response.
Will using this extended height negatively impact measurements for the other speakers?
Although a raised mic position as you suggest would actually put the mic almost level with the side surround speakers and just under the rear wall speakers.
Shelly
post #12256 of 62195
Not Jim, but I used the same procedure. First, one needs an "apparatus" that is flexible and quickly adjustable. I have a heavy-duty mic stand w/boom arm and a swivel mount. As the mic has a camera mount base, it must be adapted to mic stand threads. I did this at the last opportunity - between the swivel and the mic. (I can post pics if you need.)
Next is timing. With my OP885, there was 15 seconds between chirp sets. You need to wait 5 seconds after the last chirp to allow for decay. And you need to be "back out" and quiet before the next set. Allow 5 seconds for that. That leaves 5 seconds to step in and make the adjustment.
As I posted (a year ago when I did the setup), I only encroached one time - stepped in too soon - and incurred the Wrath of Audyssey Setup: Louder chirps! It completed that round and I was careful to be more crisp in my adjustments from them on.
post #12257 of 62195
Originally Posted by David Aiken View Post
Larry,
All of your points are valid BUT
Jeff posted those results because he obviously believes they show an objective superiority of his setup compared to the Audyssey results. As I said, I don't believe they do.
I'll give him the benefit of the doubt and assume he either followed Audyssey's instructions reasonably well for the Audyssey setup or simply measured a customer's Audyssey results in which case that bet is off, and that he did the measurements of the Audyssey setup and his setup in the same manner; in other words I don't believe he tried to "fudge" the results in his favour and I'll assume the 2 plots are directly comparable in terms of measurement methods and accuracy. On the basis of the plots he's supplied, I don't see a distinct advantage to his setup or to Audyssey but I can see enough difference to appreciate that some people would prefer one over the other.
He's obviously gathering comments from his customers and, once again, I'm happy to assume he's reporting them correctly. For the reasons I stated, I think his sampling of Audyssey customers is skewed in favour of those who didn't like their Audyssey result and who are therefore prone to want to try a different approach and to like a different result. I have no doubt he genuinely believes his results are better than Audyssey's but that is likely to be in part because his customers tend to prefer his result and in part because of his own preferences. In any event, his advertising claim that his results are superior needs to be recognised as an advertising claim and none of us believe every advertising claim we read, though we all believe some of them. I think it's a claim he's entitled to make since the superiority of one over the other is, in part, always going to be determined by personal preference. Audyssey attempts to do one specific thing, match system response to mastering standards. I suspect Jeff also attempts to achieve one specific thing with his setup but I doubt it's the same thing as Audyssey is attempting. Which is "superior" is always going to be determined in part by preferences.
Regardless of how he measures things or does the Audyssey setup, that sample bias isn't going to go away and I think he'll still end up reporting the same comments from his customers. I think any measurements or test data he provides for Audyssey and his results will always fail to show a clear advantage to either but will continue to give indications of why some people will prefer one and not the other.
So, I'm prepared to accept his data on face value and trust his reports of responses to his setups. I just don't think his results, either measured or his customers assessments, prove that his results are objectively superior. I'm happy to see an alternative method available for those who don't like Audyssey but, based on his data, I also see no reason for me to race out and hire him, or anyone else, to come in and change anything in my system when I really like the results Audyssey gives me.
Hi David,
Just to be very clear, I don't doubt Jeff's sincerity, nor did I say that he "fudged" the results.
I am merely replaying his own remarks and conclude that he is not highly motivated to take pains in setting-up Audyssey measurements.
With regard to advertising, it certainly makes sense for Jeff to claim that he can do a better job to smooth and flatten the frequency response at a single measurement location than Audyssey. What I find difficult to understand how he can do that with the relatively crude equalizers in consumer receivers. It would be appreciated if he would share more information on this point.
With regard to taking his statements at face value, I should point out that it is standard practice in this thread to request additional information from any forum member when trying to assess their observations. Jeff's professional status shouldn't negate that fundamental premise of requesting more background. In fact, if he were to provide a bit more background on how he conducted the Audyssey measurements, the graphs might take on more credibility.
Larry
post #12258 of 62195
Shelly
Some of the more nimble members of the group have managed to move the mic to different heights in between measurements. There is just enough time between speakers to move the mic down for the center speaker, for example, if its tweeter center is lower.
post #12259 of 62195
Well, I am an exception, I guess; as I said in my earlier post, I'm quite pleased with my Audyssey results (Denon 3808) for movies and TV--I want to hear things as they were intended to be heard. And I have followed the setup guide for my calibrations. However, with music, I simply want to use my own curve, which I modify now and then.
As for wanting a pro calibration, I'm mainly concerned with getting my display calibrated, and since UMR will probably not be returning to my remote area anytime soon, I will have him check out my audio as well. I'm always interested in improving my setup, whether it be with software, hardware or human expertise. That's why I visit the Audyssey thread often, and it's been even more interesting than usual lately.
Hi Mike,
Is it your understanding that Jeff will be using the equalizer in your Denon receiver to manually smooth and flatten the frequency response at a single seating location? In doing so will he be measuring the frequency response before and after that manual calibration? Will he be sharing those measurements with you?
Since you have invested the effort in setting up Audyssey and are pleased with the results, if Jeff is already taking frequency response measurements, can you ask him to take a measurement with Audyssey engaged?
By the way, are you concerned about the sound quality at locations other than the primary listening location? If so, are you also pleased with Audyssey's performance at these other locations?
Larry
post #12260 of 62195
I never changed the height of the mic, just rotated it around the three axes. I don't think I could have made adjustments beyond that in the allotted time. But then the mic could "see" all of the speakers and did not need a height change.
post #12261 of 62195
Jack be nimble, Jack be quick, Jack jump fast for the Audyssey fix......Not to reopen the whole "how much sound does the human body absorb/reflect" issue, but for those contemplating such precisely tailored mic angles in rapid sequence, wouldn't it be fine to just sit quietly on the floor a few feet from the mic stand/tripod during the chirps, as long as you are not directly between mic and speaker?
post #12262 of 62195
Was your mic facing the speakers? If so, I can understand your method.
But with the mic pointing straight up, it doesn't seem that rotating it on my tripod would change any thing.
Shelly
post #12263 of 62195
The mic is only active for a few milliseconds before and after each chirp so really have almost the whole 15 seconds.
post #12264 of 62195
What about pointing (tilting the cabinet) the tweeter to the ear height when seated, also called Boresighting.
Wouldn't that work effectively?
post #12265 of 62195
Hi Andrew,
Larry
Hi Larry,
Sorry, I actually posted the graphs in a separate thread. See here:
http://www.avsforum.com/avs-vb/showt...1#post15916986
Cheers,
Albert
post #12266 of 62195
[quote=Kal Rubinson;15954074]
. What is relevant, as you have demonstrated, is that its radiation pattern, as a line source, is significantly different from that of small symmetrical tweeters. That is why a different measurement approach (or, if Audyssey was to engineer it) a different calculation approach is necessary.
So it relates to the radiation pattern and has nothing whatsoever to do with the response of the particular speaker, Kal?
1. Maybe.
2. Maybe not.
3. Maybe all of the above.
Jim
post #12267 of 62195
So.
Garrison, since the test "chirps" are sequenced to go around the room sequentially (and I have seven speakers and two subs), it's fairly easy to make your adjustments such that you can step out of the way of the speakers that will be tested next, and out of the area between the mike and the tested speakers. - After positioning the mike, I just try to step back, out of line with the ongoing or upcoming tests. For the first three positions, of course, it's fairly easy to simply step back a few feet after making an adjustment. For the fourth and sixth test, again, it's easy to step to the nearmost side of the room, out of the way of the mike and the respective speaker.
It does seem to improve things, and I found that there is ample time between chirps to get out of the way. I do try to remain still for a few seconds before and after each chirp so that I don't create any disturbance while "listening" is still in progress.
Jim
post #12268 of 62195
Jim, how is the NAD 175 characterized with respect to "openness" and what is powering your system?
NAD states that it's design philosphy is "Music First," and they do have a reputation for good audio, which I assume includes "openness." I do think it's very good, particularly in the analog audo-bypass mode, but I'm not sure that the sound is as good as my old Carver preamp's for stereo. I personally think that any processing or equalization circuitry interposed between the source and the speakers adds at least some degree of distortion and loss of transparency. On the other hand, processing such as Audyssey's enhances the results and reduces other types of distortion. I guess it's something like the Stones tried to tell us years ago. - "You can't always get what you want."
Bottom line is that I haven't done any controlled blind testing comparing the NAD unit and any others, and it's a pretty subjective judgement with respect to the basic (unprocessed) audio quality. - Was that the point of your question?
Jim
post #12269 of 62195
You are a nimbler Jack than I if you can sit on the floor and spring into action that quick. I was off to the left side for all of my resting periods, such as they were. For front, rear and right speakers, I merely retreated and minimized my profile; I bent over and leaned on the arm of the left rear recliner. For the left side surround speaker, I crouched in the same location.
post #12270 of 62195
I ran Audyssey on my Denon 2809 today while the house was quiet, and using the "official setup guide", it reported each speaker to within inches of it's actual position from my listening seat. I first equalized my two subs with the suggested 72dB each, and that yielded a 75dB response for them together. Audyssey brought them up 3.5dB, and the most any speaker was increased was about 5dB for a side surround quite far from my listening position. The sound using Audyssey flat may take a bit to get accustomed to, but I'm going to give it time for music listening. Overall, great stuff!!!
