AVS › AVS Forum › Audio › Receivers, Amps, and Processors › "Official" Audyssey thread (FAQ in post #1)
"Official" Audyssey thread (FAQ in post #1) - Page 418
post #12511 of 62292
Originally Posted by QueueCumber View Post
Kal, do you use the inverted triangle method in the Audyssey FAQ?
I don't know what that is but my situation is that there is only one small row of seats on one couch. I usually use the same 8 mic positions now. 3-1-2 across the couch, 4-5-6 a bit in front of it and 7-8 a bit lateral to and a bit higher than 3-1-2. Often lately, I add an additional measurement at position 1 to bias the results a bit for my seat.
post #12512 of 62292
Here is the FAQ setup text:
The first microphone position must always be in the center of the listening area. Then we recommend moving the mic about two feet to the left of that first position for measurement two and two to the right of the original spot for measurement three.
If you are running MultEQ or MultEQ XT you should use all six or eight measurements available. The next three should be taken about two feet in front of the first three. The final two measurements (if available) should be about one foot to the left and right of the first central measurement and about one foot forward to form a triangle.
You should avoid taking measurements that are too far off to the side and outside the front Left and Right loudspeakers even if there are seats there. These measurements will suffer from a drop in high frequencies and can cause the room correction filters to compensate for that unnecessarily.
Also avoid taking measurements too close to the back wall even if the only listening seats are up against the wall. Move the mic at least one foot from the back wall to avoid the bass build-up that happens there.
So your mic setup is like this? (two spaces = 2', one space = 1')
Code:
  4  5  6
8 3  1  2 7
I'm trying to figure out what I will try out on my next group of measurements when I get time next week...
post #12513 of 62292
Code:
  4  5  6
8 3  1  2 7
In 2 dimensions, yes.
post #12514 of 62292
I suggest you download the latest version of the Guide for your reference, as some of the wording and illustrations have been updated by our most dedicated giomania(thanks). The mic pattern is more of a rectangle shape, but I believe Chris has indicated that the exact pattern is not so crucial as is the idea of sampling in a pattern that envelopes the main listening position. I think it would be helpful to suggest in the guide that the primary listening position (PLP) be at (or as close as possible to) the sweet spot, "the center of the listening area". My latest Audyssey rerun included some measurements behind PLP, putting a blanket on my leather recliner and more attention to assuring the mic is vertical. With the valuable suggestions on this thread, each run gives me better results.
My pattern:
(one space = 1')
4 5 6
3 1 2
I can't get the spacing right in the post illustration but 7 is 1 space below and between 3 & 1, 8 is below and between 2 & 1.
post #12515 of 62292
Official? What does that mean?
Comparison of Audyssey with 8033: http://stereophile.com/musicintherou...34/index1.html
This is definitely along the lines of the comparison I was looking for (to my ears the 8033 absolutely helps the MCACC/Elite (and better than my DEQ2496) but I was not sure about Audyssey and have not tried it in combination).
Am I correct that your comparison is effectively against the Audyssey MultEQ Pro setup available to the SEQ? Do you have a feel for whether someone using a standard Onkyo or Denon MultEQ XT system without a pro calibration would benefit from adding the 8033?
(which is what most of my friends use, very few bring in the pro cal service)
Your plots are great, it was the first time I saw a review doing a side by side.
post #12516 of 62292
Double thanks to both of you!
post #12517 of 62292
This was done on the Integra's MultEQ XT although with the Pro kit. So, it has the same resolution as any MultEQ XT setup. I use the Pro for the better mic and more setup options although none of the latter were exercised in this comparison. Thus, I think one can expect similar results with the stock MultEQ XT setup.
Thanks. As a professional scientist, I like to see the data even though I trust my ears. If there's no discrepancy, I am happy.
post #12518 of 62292
Yup, data good (or as we said in grad school, data good, toss me another beer)
Thanks again.
post #12519 of 62292
giomania et al,
Should this - The first microphone position must always be in the center of the listening area. - be slightly re-worded to say that the first position should always be in the listening area and on the centerline between the left and right front speakers?
I'm trying to think of setups where the center of the listening area is not centered between the left and right speakers.
post #12520 of 62292
"Like Chris previously mentioned, the microphones with the flat shape (hockey
puck) are of imprecise measurements, due to their early reflections by the
plastic contour."
Chris, is this really an issue?
It looks like the plastic housing has been carefully shaped to reflect sound away from the mike.
Would it help to cover the housing with a piece of 1/4" or 1/2" thick felt with a hole in the middle?
post #12521 of 62292
Originally Posted by pepar View Post
giomania et al,
Why not place the first microphone position where you want the levels
and the delays of the speakers to be equal
Which is probably the center of the listening area for most people.
post #12522 of 62292
Hi,
I've been looking into a particular subwoofer and came across a review that said because of the peak in Frequency Response (FR) at 60-65Hz, he used a parametric equalizer to tweak the curve, resulting in much better performance from the subwoofer.
(See last graph in review here: http://www.hometheaterhifi.com/volum...er-1-2005.html
My question is: Can/will Audyssey MultiEQ (I have a Denon 789) flatten the FR also, making this a usable subwoofer?
Thanks, Adam.
post #12523 of 62292
My pattern:
(one space = 1')
4 5 6
3 1 2
This is the microphone positioning I used on my last calibration as well. Except 7 is below 2 and 8 is below 3 not between them.
John
post #12524 of 62292
plastic contour."
Hi Noah,
Yes, it is a big issue. The puck mics had the wrong shape and there is nothing that can be done to make them better. We finally convinced manufacturers to stop using them...The biggest problem was that the precision of the 1/4" mic capsule was compromised by adding a 2" plastic puck around it thus greatly affecting the high frequency performance and also the true omnidirectional nature of the mic.
Absoprtion on the housing with a hole in the middle doesn't help. The biggest problem is that the sound arriving from the rear is attenuated relative to that arriving from the front and the mic is not a true omni because of that.
post #12525 of 62292
Originally Posted by WrJr View Post
Hi Nordo thanks for the info but I have allready done what the setup guide has said. I've read it and even printed the whole thing out to have with me during the setup. As far as moving stuff around I cant do much about it because of the way the living room is...the front door is in a weird spot and right in the middle of the wall. If I move the sofa out or the speakers away people will not be able to get in the door lol. So thats why I have it all setup the way I do. The part that confuses me the most is the mic setup on the posistions when it is doing the calibration. This love seat is small so its hard for me to figure out where to take a mic posistion from. Oh and the front speakers are about 5 inches from the rear and side wall...the manual on the speakers suggests at least a few inches away if you gotta be near one so thats the best I could do. I could move the sofa out temporarily but it would have to go right back up against the wall afterwords. I did not do that because I thought it would defeat the purpose of the auto cal. Thanks again
Leaving everthing where it is, Audyssey will try to compensate for all the anomalies of the room. I just like to give Audyssey a hand by trying to make the room and speaker/seating positions as close to the ideal as possible, thereby letting Audyssey do more of a fine tuning job than a massive correction job.
However, leaving things where they are, when taking tests on and around the sofa against the wall, take your first tests at head/ear positions (with the first in the centre head position). Hopefully these will be at least 12" from the rear wall. Audyssey will try to compensate for the increased low frequency pressure zone near the wall.
My feeling is that your remaining test locations should NOT be too far in front of the wall. Say, only 12" maximum in front of the head positions. If you move too far from the wall and the head positions, this will reduce Audyssey's compensation of the low frequency gain near the wall and you will probably end up with a boomy result when sitting on the sofa.
This should give you a good setup in spite of the nearness of the sofa to the wall. However, you will also find that the result Audyssey gives you will be lacking in bass if you move away from the sofa.
Chris may like to comment on this approach.
post #12526 of 62292
Originally Posted by audyssey View Post
Hi Noah,
Chris,
I probably know the answer already, but is there any possibility that the new mics will be available for older receivers, complete with firmware upgrade for the different calibration, etc?
post #12527 of 62292
i have a question. if it has been covered forgive me.
when i run my onkyo 705 in pure mode with 5.1 material, what does it do to audessy?
i assume it shuts it off. but do the delays still stay in place?
i ask for i have twin epik towers, and when i watch movie a 5.1 movie in pure mode it is crazy.
i would like to hear any imput on this,
thanks,
mike
post #12528 of 62292
Chris,
First, is the mike in the pic the one you're talking about?
"The biggest problem is that the sound arriving from the rear is attenuated relative to that arriving from the front and the mic is not a true omni because of that."
It has circular symmetry; how do you define rear vs. front?
post #12529 of 62292
hey guys, I am confused as to what are the proper positions for the microphone in my seating arrangement. I have a really long couch which is the only seating in the room. It has five "sections" attached together. Each section basically fits one person really comfortably, but the couch can easily fit 10+ people so its quite long. What are the proper mic positions for this seating arrangement? I did 5 measurements starting with the center, then the position to the left of the center, then the position to the right of the center, then the far left section, then the far right section... I basically used the center of each section as a listening position. Should I have done something differently? I imagine I should be covering positions around this area as well?
edit: forgot to mention I am using an integra dhc 9.9 preamp... Also, when I ran the audyssey initially, the sq that resulted was good, but not great. The bass especially was horrible, and very quiet. After I raised the level of the sub, the bass is still lacking the deep bass that it used to give off... I am hoping when I rerun the audyssey with the proper positions this will change..
post #12530 of 62292
Originally Posted by Nordo View Post
Chris,
I sent him a PM and he told me that no, the newer mics cant substitute the puck style mics (but I guess your asking if they will make new mics just for older models, in that case it would be awesome considering the puck mics are not as accurate according to Chris). In my case its a bummer because I just had to order one for $20, even though I have the newer mic (But I guess $20 is not so bad when you consider you spent $1500 on a receiver)
post #12531 of 62292
Originally Posted by PerfKnee View Post
Many thanks for posting your results. Do you have wood or carpet floors? I would think that for a person with wood floors, having a coffee table with stuff on it might improve the sound by breaking up the reflections off the wood floors. But a person with carpet might not have such reflections as much and therefore might be better off without the coffee table if feasible. Of course this is pure conjecture on my part.
Chris, I'm curious if Audyssey corrects in the time domain for late reflections (e.g. higher frequencies bouncing off a coffee table or wood floor). Obviously it would correct frequency response to whatever degree the coffee table or wood floor changed it, but my understanding is that audyssey not only corrects frequency response but also does some processing affecting the time domain, cancelling some reflections perhaps. The fact that you have never expressed concern about the person being in the room near the mike during calibration makes me think perhaps audyssey somehow avoids correcting for late reflections off the person.
Hi,
Sorry to not mentioned it, I do have my floor carpeted wall to wall. And it's a
pretty thick carpet too, so very absorbant. And I also have a glass door plus a cabinet with also glass doors behind the couch in the back of the room at approximatively 10 feet from the main listening position. But I covered both of them with some nice fabrics made of cotton and silk of reasonable thickness, to stop the rear reflections. My room is also kind of treated with some diffusion and absorption. I try to get a proper balance of sound.
Your assumption is very valid. And Audyssey is correcting for the response by the microphone, furniture or not. But by starting with a good sounding room, it will help Audyssey job to perform better results. Don't you just love it, help Audyssey and Audyssey will help you back!
Glad that you like my little experiments.
Cheers,
_______ Bob
post #12532 of 62292
Thanks Nordo I really appreciate the help and advice. I hope Chris chimes in as well about the mic posistions. And yes when I did the calibration on the sofa it was about 20" from the back wall right in the 2 sofa seats. The thing is wide from front to front but not very long from side to side. I guess that can help keep my listening away from this back wall some. I will do some more testing yet again later tonight when things are not as noisy here. I have been turning every single thing off in the living room and kitchen during setup along with the pc here. Its always dead silent no tv fans no cable box funs no hvac nothing. But I can see where my original problem was with maybe not having much bass(or maybe im not use to things sounding correct). I was taking my last 3 additional test about 5 feet out in front away from my main listening spot. Ill try your approach and stay within 12" inches this time thanks. The sub always says the right distance to and never usually off by more then a half foot or so and audyssey always sets it to around -2.5db or +3.5 never higher or lower. I got the subs crossover off and the volume set at half way per the guide along with the phase set at 0.
post #12533 of 62292
Originally Posted by LarryChanin View Post
Hi Bob,
I agree with you that Andrew's courteous remarks concerning alternative microphones to the standard Audyssey microphones are certainly relevant to this thread, even if the subject does interest everyone.
However, in my opinion Andrew has failed to make his case either in this thread, or in the Audyssey measurement with non-standard mic thread that he started in response to a request from Jeff (QueueCumber).
Larry
Hi Larry,
Glad that you find ALBERT (not Andrew, by the way) competant to this thread
and with some interesting relevance about Audyssey measurements.
As far as measurements and graphs with curves, I am not an expert. All I found captivating is the discussions between Albert, you and Chris; the three
main players. And I am learning a great deal more, so thanks to all of you.
I find it very positive learning in the end, and that's what it's all about.
I am my own judge of my interpretations; I keep what I believe is good for me
and I just discard the unecessary. But the process to getting there is what is
the true captivation. By being captivated, you search and experiment on your
own, and that's how you always improve.
Cheers,
_______ Bob
post #12534 of 62292
Originally Posted by zadam View Post
Hi,
Thanks, Adam.
Yes, automatically and better.
post #12535 of 62292
Originally Posted by Lordoftherings View Post
I do have my floor carpeted wall to wall. And it's a pretty thick carpet too, so very absorbant...
Hi Bob,
A more probable explanation for your preference is that you've become accustomed to habitually listening to the added distortion produced by the reflective coffee table over the more accurate response afforded by the better acoustics of the absorbent carpet.
In all likelihood you were helping Audyssey produce a more accurate response when the coffee table was removed, but you simply didn't have enough time to get used to the that type of sound.
Larry
post #12536 of 62292
Hi Larry,
Cheers,
_______ Bob
Hi Bob,
Thanks for the correction. My sincere apologies to Albert, I'll correct my posting to avoid confusion.
So, based on your interpretations, do you plan to replace your standard microphone with a more expensive one, or have you discarded these microphone observations as unecessary?
Larry
post #12537 of 62292
Hi Bob,
Larry
Hi Larry,
Very smart deduction, I must agree.
But still my coffee table is totally covered by a cotton table nap and full of magazines plus drawings, etc., 1 to 4 inches thick. I am a big reader and always drawing things. There is absolutely no wood surface exposed. And my center channel is fully in view. In fact, the coffee table becomes an absorbant of sound, just the way I intended to.
Remember, I work on this for many years, and I did live without the coffee table for over a week, enough time to get accustomed.
In the end, I choose sound first & then practical benefit.
But your point is a very good and important one.
Thanks for mentioning to all of us. It should be part of the Audyssey bible.
________ Bob
post #12538 of 62292
Hi Bob,
Larry
All right Larry. I am using the mic that comes with my receiver as for now.
But I am experimenting with different mics just to check things out. When I find something worth mentioning, I will not hesitate.
I found that in general, you can always use different alternatives if applied
with a common sense.
Cheers to you Larry,
_______ Bob
post #12539 of 62292
Originally Posted by fyzziks View Post
No, that's certainly not the case for your speakers at only 10-12 ft distance. Unless the phase relationships of radiation at different points on the ribbon are manipulated to change the radiation pattern, you should have a cylindrical wave coming off that tweeter at 10-12ft. It won't be perfect, due to diffraction off the baffle edges, but it should still be really good, and so the wavefronts should be parallel with a vertical mic orientation. It's only from very large distances that all finite sources look like point sources.
I don't mean to sound disrespectful, but what's the basis for your statement? Are you an acoustical engineer? If so, I stand corrected. For clarity, I'm not suggesting that the sound is completely disbursed by the time it reaches the microphone, but rather that substantial disbursion will have taken place.
Jim
Jim
post #12540 of 62292
You type
Code:
 and
at the beginning and end of the text that you want displayed as-is.
Jim
