On the Audyssey website? Where exactly is that information? I can't find it.
Oh, I see - when it says "Installer Ready" that means MultEQ-Pro ready.
Running out of options, I just tried.
The Distance to the Sub is reported longer than the actual physical distance. And Chris said it is normal. I forgot his explanation ( somewhere in this thread ). Subs are difficult to understand.
vis-a-vis the speakers in my 7.1 system. Only once during all sixty-four measurements did I encroach time-wise on the process; I stepped in too soon after a side surround measurement to re-position the puck and got the admonishing raised volume chirp re-do. I contemplated aborting, but went ahead anyway. After the 885 display said "calculating" I fired up the video chain. I had no basis for an expectation of how long the calculations would take, but nonetheless it took longer than I expected. My anxiety to review the settings obviously made me impatient. And reading so many posts here filled with "Audyssey killed my XXXX" wasn't a mitigating factor.
That was what Audyssey passed along to my pre/pro as where to cross them. Both sets of surrounds are the same, but the sides are wired for dipole and the rears are wired for monopole. As dipoles, the opposing (side) drivers are active, while as monopoles, the front drivers are active. Plus, perhaps, their different locations in the room played a part in the "decision." Those are the differences, but I can only guess if they are factors.
