Originally Posted by FilmMixer
Chris... I have a new Denon 4310 in my system for a spin... I noticed that when doing my first setup, it had me turn down my sub until it was at an acceptable level... I've never seen this in a setup before..
I assume this is a newer addition to the Aud setup, and was wondering if there are any other "tweaks" in newer processor and AVR implementations?
Yes, Chris has posted that this addition was a result of feedback from the thread. It saves the time of doing a single mic position test and then ending and reviewing before going back and doing all 8 positions.
http://www.avsforum.com/avs-vb/showt...7#post16699547
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
Compared to Klipch's $20K P-39F or some other $50k speakers, the RF-62's are less expensive, but cheap (not very good), I think not! Cheap speakers are tiny little satellites that can't move air. If a speaker is too small to move a lot of air, it's cheap and sounds "cheap". That speaker is rated by Klipch down to 38Hz. That's no slouch.
Since both of my subs are actually 12' 3" away from th primary LP, I was confused by the Audyssey setting. Audyssey had never found the subs that close before, and it had always "nailed" the distance measurement.
