I wanted to run this by and see your suggestions. My trim levels after Audessey calibration are set as follows:
FL: -3.5
FR: -3.0
C: -4.0
SW: +6.5
SL: -1.0
SR: -1.5
Crossovers for all speakers are set at 90 Hz.
I set the LFE setting for blu-rays to -7db (which has helped reduce bass output). My SW is setup in the right corner of my living room (19.6 ft away), I know that is not an optimal location, but I prefer it to be hidden from my primary viewing area. Right now I am getting reference level bass (which at times is too much) and want to lower it.
My question is, can I lower the SW trim level from +6.5 to say +2.5? If so, will this mess up the MultiEQ calibration settings? I want to lower the bass level without adversely effecting any of the Audyssey MultiEQ setup. My SW volume is set to 30%, so I don't think adjusting that and re-running Audyssey will produce different results, as Audyssey will just offset the trim level of the sub.
FL: -3.5
FR: -3.0
C: -4.0
SW: +6.5
SL: -1.0
SR: -1.5
![A Woman, a Gun and a Noodle Shop [Blu-ray]](http://cdn.avsforum.com/d/dc/50x50px-ZC-dcb2c66f_B0041KKY9W-51thImgXmFL.jpeg)
, to avoid confusion with LarryChanin!),
Or if the PS3 has an LFE decode problem, maybe those trailers didn't use much/any LFE...
